help near Philadelphia PA
hello all
I am in the beging stages of a project and need some help. I need the rear wall to a 73-87 chevy pickup cab. I need this for my suburban. do to rust issue i want to make it into a crew cab short bed. If anyone here can help me out with a location of the rear wall and maybe some tips it would be appriciated thanks mike |
Re: help near Philadelphia PA
Cool project!!! Definitely post pics when you get started. Sounds cool!
where were you over the summer. I had 2 trucks I cut up that you could have had the whole cabs if u wanted.... I know of several 73-87 cabs over here in Jersey junkyards if your willing to drive. Its about 45mins-hr from horsham. Otherwise you should have decent luck @ the JYards down on Essington. But you'll be payin for it....
just my luck
well if you run across any let me know I am going to the yard tomorrow to look around |
I had a cut down a 1 ton 3+3 and installed a factory short bed from a junkyard truck. Pretty basic stuff. You might want to try that should be alot easier than a burb.
Have an 86 cab I'm almost ready to part with. Only live about 10 miles from you. Shoot a PM
| All times are GMT -4. The time now is 06:41 AM. |
