-   -   where to find passing gear/kickdown switch supplier (https://67-72chevytrucks.com/vboard/showthread.php?t=226147)
fourty1 02-05-2007 09:39 PM
When the orig.327 was yanked from the engine bay of my 67 3/4 ton, the kickdown switch went with it.
I had a Transmission shop check it today, & they said i needed a ' kickdown' switch. I was led to believe it as an electric switch.
I have all the wires from the transmission.
I believe it was mounted on the intake manifold, behind the carb..
My engine bay now sports a GM crate 350, with the original transmission.
I'm looking for suppliers of this switch or ?
I've checked LMC ( pgs 117 detent cable )
and
YearOne ( pg 135 kickdown bracket )
BTW,... thanks,
jim:hmm:
Livrat 02-06-2007 12:32 AM
Re: where to find passing gear/kickdown switch supplier
Trucks up to 1970 used one bolted to the rear carb stud.. here is one on Ebay.. They tend to get quite expensive..
http://cgi.ebay.com/ebaymotors/ws/eB...MakeTrack=true
Here is a reproduction bracket and a used switch from DR Classics.. scroll down to page 292..
http://www.drclassic.com/images/cata.../Underhood.pdf
JimKshortstep4x4 02-06-2007 06:03 AM
2 Attachment(s)
The switches and brackets are available new and there are aftermarket versions. Attached is a picture of the original switch as installed. Also attached is a picture of the available parts with the vendor information.
Jim
fourty1 02-14-2007 09:53 PM
FYI , Thanks for the info LIVRAT & JimK SHORT STEP 4x4:
My supplier , had a Hurst universal kickdown assembly,( as pictured above in the Firstgen.com catalogue page 43, priced at & 29.95 packaged as a
B&M Kickdown switch kit # 20297, priced at $ 48.oo. Installing tomorrow,...
jim
