91 Suburban Dash Shell
Has anyone put the suburban dash shell in their trucks? I am looking into this for one, the use of a double din radio(late model Monsoon) and second, someone decided they wanted my cd player more than I did and trash the dash shell that is in the truck now:mad:
Anyhow, I have to take this shell out and decide what I am gonna do from there. damn:cuss: :censored: |
Re: 91 Suburban Dash Shell
IS the dash shell the metal behind the dash ot the instrument panels palstic?
Using that late model dash bezel would be awesome. You could use an GM installation kit for a DIN radio to come out with a very professional look. .
I too would like to know if the metal dash shell is different or if it's just that section where the radio is that is different. If the late model dash bezel itself will match up and the metal behind it for the radio opening can be modified, I would be willing to do that. Sucks about the radio. If the dash shell isnt seriously bent, you may be able to get away with cutting out the radio section and riveting a new piece of sheet metal in along with replacing the dash bezel which I assume the thief also broke. Changing out the entire dash shell would be a real chore so personally I would opt to repair it if possible. Got any pics of the damage ? |
well then yes you can use it with out trouble. just watch out it is tack welded up top.
And as for stealing radios, thats why i put razor blades on the back side of the radio. THEY WILL BE CUT. |
