-   -   Firewall Distributor Clearance Question (https://67-72chevytrucks.com/vboard/showthread.php?t=233343)
Eyegore 03-26-2007 09:29 PM
2 Attachment(s)
Were finalizing things on the truck and were noticing how close the distributor is to the firewall, about 3/8" around - how close should it be?
Here are a couple of pics, not to good but you'll get the idea.
pcmcobra 03-26-2007 09:37 PM
Re: Firewall Distributor Clearance Question
that's pretty close.
What motor you put in there?
Zilverado 03-26-2007 10:12 PM
It looks a tad close to me too. It's a little tough to see from the photo below, but I would say that mine is about 3.5" from the firewall to the centerline of the distributor.
Can you even get a screwdriver back there to remove the distributor cap hold-down screws?
BTW, mine is a stock 305 engine.
Eyegore 03-26-2007 11:35 PM
2 Attachment(s)
Sorry guys this is on the 78 k10 w/ 350, this one:
Billy81 03-27-2007 12:01 AM
Did you lower the transfer case when you did the lift? If so thats why it is so close to the firewall. I just put a 4" lift on my 86 Blazer and i had to lower the transfer case to get better drive line angles. And my distributor sits pretty close to the firewall just like yours.
Eyegore 03-27-2007 12:32 AM
Billy I believed you nailed it. Are you having any trouble with a cracked cap from hitting the firewall?
Billy81 03-27-2007 01:30 PM
No broken caps yet:c2: I was talking to a guy at a local 4x4 shop and he told me that it should be fine running it like that. But he also said i would be better off if i put the transfer case back and get a new rear driveshaft made with a cv joint. I will admit at first i had no idea what he was talking about but i did know that i did not have $600 for a new driveshaft..lol
tiggerstoy 03-27-2007 01:36 PM
:agree:
