HEI timing curve thingy
A year ago I discovered the original mechanical timing curve thing, was worn and broke. Then I discovered you cant just buy a OEM type replacement one at most parts stores unless you buy a whole nother brand new $$$$$ distributor too. :whine: So I bought a made in china "high performance" "curve kit" but It was not what I needed. The only way I could get it to not ping was to unplug the Vacuum advance, killing my gas milage. :( I didn't worry about that till now. The gas prices are high again at im sure one or two of you have noticed :rolleyes: and I need optimum gas milage now, so sorry for the rant :blah:
My question is where can I get a *new* OEM curve kit?? thanks:b69: |
Re: HEI timing curve thingy
This is my mechanical advance curve kit. Mr Gasket #929g http://performanceparts.com/part.php?partID=74317
I just read http://www.thirdgen.org/hei Maybe its the vacuum advance that i need. On mine is not adjustable. What is a good adjustable vacuum advance? I have to run 4 degrees retarded or suffer "3 rocks in a coffee can" detonation or drive with the vacuum capped off like I have for the last year. Question again if you don't want to read all that: What is a good adjustable vacuum advance? |
well im going to put an msd setup under the hood. save a little on gas. Plus i plan to at one time go back to tbi (have no idea why i removed it)
As for your stock curve advance go to a junk year theres plenty to choose from. |
Thanks. Actually I had that saved that under my favorites ;) It says to get a "vacuum advance can that is adjustable for both RATE AND TOTAL ADVANCE" IE Crane
Bought this: http://cgi.ebay.com/ebaymotors/Brand...QQcmdZViewItem This is adjustable just for total vacuum advance as far as I know. :( I am sure it is a lot better than having NO vacuum advance, like i have now. :rolleyes: Should I have gotten one that is adjustable for rate too? :o |
http://store.summitracing.com/partde...1&autoview=sku
Summit Racing part number CRN-99600-1 $29.99 Im not sure if it would would be the same without it or not. Here is a link for the manual also http://static.summitracing.com/globa.../crn-210g2.pdf |
