-   -   ? on glovebox options (https://67-72chevytrucks.com/vboard/showthread.php?t=252518)
project 67 sub 08-04-2007 07:21 PM
these are on my 67 C10 burbs glove box door.
1. 04B98GA- SIDE TRIM MOLD EQ
2. 04G50FA- HD REAR SPRINGS
3. 04K24GB- CLOSED ENG POS VENT
4. 04M49HN- TURBO-HYDRAMA-MATIC
5. 04PO3AA- CROMED HUBCAPS
6. 04V37GJ- CHROME-BUMPER FRT&R
7. 04Z61CA- CUSTOM APPEAR INCL
8. 04001KG- SPECIAIL PAINT
9. 04A11BK- TINTED GLASS
10. 04C42CB- DELUX AIR HEATER
11. 04K19NG- GM AIR INJ HEATER
12. 04K76CC- 61 AMP DELCO GEN
13. 04N40HA- POWER STEERING
14. 4U63HH- PUSH BUTTON RADIO
15. 04Z53BR- AMMETER-OIL GAUGE
16. 04Z62BJ- CUSTOM C&C EQUIP
What does option #3,7,8,11,16 consist of and what are they?
On #4, what transmission did it come with?
oh and half the model # is missing, all I can get from it is
CEIO9 AND BASE 127. Also their is no engine code for the one that it came with.
project 67 sub 08-04-2007 07:51 PM
Re: ? on glovebox options
bump
1967C20 08-04-2007 08:11 PM
#3 is the Positive Crankcase Ventilation (PVC) system and #11 appears to be the Air Injection Reactor or smog pump (California trucks). Regarding #4, I believe that in 1967 the only Hydra-matic offered on trucks was the Turbo 350 3-speed. I don't know about the other ones on your list but I am sure there are others on this board that can help you.
Longhorn Man 08-05-2007 05:40 AM
actually, the TH350 came into play in 69, that would be the TH400.
If no engine option is listed, then you have to look at the VIN. If it starts with CS or KS, then it'd be a 250 inline 6... if it starts CE or KE, then it'll be a 283.
Z61 Custom Appearance option: Chassis and cab & pickups only; includes bright metal grille moldings, headlight bezels, vent window frames & windshield moldings, control knob trim, horn button cap; color keyed vinyl coated rubber floor mats; custom emblems. Not available with Custom Sport truck option os ordered
Special paint... an odd ball color or color combo, but not way out in left field to call for a COPO deal.
Z62 Custom Comfort Option: Chassis and cab & pickups only; includes RH & LH arm rests, RH padded sunshade; cigar lighter; special cowl insulation;full depth foam seat with fabric upholstery; under body coating; vinyl door trim. Not available with Custom Sport truck option is ordered.
project 67 sub 08-06-2007 08:29 PM
bump
special-K 08-07-2007 01:39 AM
Custom C&C=Custom Comfort & Covienience pkg which is the custom model interior.
Custom Appearance pkg=It`s a "Custom".Does it have a badge on the door under the window?
Isn`t it a COPO to get a none production color,alone?Aren`t the codes different like with COPOs?
Longhorn Man 08-07-2007 05:17 AM
I've been noticing a few that are not normal paint, but not COPO.
What is the original paint color/scheme?
special-K 08-07-2007 06:13 AM
Yeah,I don`t know what determined a COPO as far as paint goes.I`ve seen trucks with what appears to be normal options except special paint have the normal codes and some with special codes which I always took as one way to determine a COPO.
Tell us more about your vehicle.Got pics?#11????
Longhorn Man 08-07-2007 04:53 PM
I'm 99% sure a COPO truck would say it on the SPID. I've seen a few that did.
special-K 08-07-2007 05:35 PM
Aight!Maybe the numbers vary when there`s just special paint or anything else that keeps it runnung throught the line with the rest.
project 67 sub 08-07-2007 07:15 PM
the original color was gold with a white top
project 67 sub 08-07-2007 08:14 PM
5 Attachment(s)
well here goes. it's a 1967 c/10 chevy suburban that i lowered(cut springs, soon to hopefully be bagged & tuckin 20's & layin frame. workin on it as we speak). had the windows tinted, 74 c/10 disk & crossmember swap, temporary army camo tan paint, mid to late 70's 350 hopefully soon to be ditched for the mildly built 350 im working on. it has a th400 trans(hope to get it rebuilt soon as well), going to also ditch the tired 6 lug rearend for a 76 c/10 5 lug rearend that i have. going to start doing all the body work and mods after the suspension is done.
Attachment 289068
Attachment 289069
Attachment 289070
Attachment 289071
Attachment 289072
project 67 sub 08-07-2007 08:15 PM
and what i want it to look like minus the paint color and add a 5" cowl hood
Attachment 289078
Longhorn Man 08-07-2007 09:01 PM
stupid question here...
where's the brake lights?
Otherwise... I dig it!
special-K 08-07-2007 09:43 PM
In place of the reverse lights?
HeavyD 08-08-2007 12:29 AM
ANother special paint truck! Wish there was a way to tell what these colors were named, if they were used from another GM line or whatever.
project 67 sub 08-08-2007 03:46 AM
loghorn man & special-k.
yes the taillights have been moved to where the original ones used to be(only because the taillight buckets were gone). the way that i have the taillights set up right now is only temporary as i have a set of caddy tails that will be going in it.
special-K 08-08-2007 06:20 AM
Kewl...So,just what color(s) will this smoothy be?
project 67 sub 08-08-2007 07:14 AM
im thinking maybe painting the top white again and the rest of the body a 2002 dodge neon light almond or a tan color like i have it now
