-   Suspension (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=25)
-   -   RE6s ok for rear (https://67-72chevytrucks.com/vboard/showthread.php?t=253207)
mrenj23 08-09-2007 09:57 AM
RE6s ok for rear
I have a an 86 1/2 ton and I was wondering if RE6s would be ok to run in the rear. I need the extra clearance.
Kontrol Phreaks 08-09-2007 10:44 AM
Re: RE6s ok for rear
If you are running into width problems and a RE7 wount fit, then you might want to consider using a F9000 bag. It's only 5.5 in dia, which is even narrower then the RE6, but you will get a great amount of lift from tha bag.
The RE6 will be fine, the only draw back is that you're not going to get the lift that you would if the truck had a RE7 in the back.
