-   -   Has any1 installed the euro style headlights and hd wiring from lmc? (https://67-72chevytrucks.com/vboard/showthread.php?t=254037)
84_chevrolet 08-15-2007 09:52 AM
I am wanting 2 put euro headlights in my truck. Is the lmc lights just a plug and play operation witht the new bulbs? How much more light is produced with these lights and the hd wiring harness with relays? any pictures of before and after would be appreciated
knightlife 08-15-2007 12:16 PM
Re: Has any1 installed the euro style headlights and hd wiring from lmc?
the instructions are in japanese...if that helps any :D
77 350 Shorty Wide 08-15-2007 12:47 PM
I did the switch, don't have any before and after pics.
They're suppose to be plug & play wiring but mine wasn't. Their connector was wired incorrectly, had the hi and low beam wires switched. I swapped them and everything is now ok.
I haven't yet had them out on the road yet... but they are quite a bit brighter on the garage wall.
On a scale of 1 to 10 rating for over all ease of install I would rate it a 8. That's because I'm not an electrical guy... but with a schematic from a service manual and trial and error I was able to have it fixed fairly quickly.
Overall I would say a good experience.:)
God Bless, Terry
LBJ 08-15-2007 01:04 PM
If you are good at these things, here is a link to make the harness yourself.
Plus, some additional information on the subject.
LBJ
http://73-87.com/7387garage/exterior...ight_relay.htm
knightlife 08-15-2007 01:11 PM
invalid link...
Jim85IROC 08-15-2007 02:26 PM
works for me.
84_chevrolet 08-15-2007 02:59 PM
Can the bulbs in the lmc light be changed like the neweer cars by just a screw in bulb or is it still a sealed beam light?
Jim85IROC 08-15-2007 03:31 PM
They have a replacable H4 bulb just like most newer style cars.
Captkaos 08-15-2007 07:05 PM
Originally Posted by knightlife (Post 2310820)
invalid link...
Did you click it or copy/paste it. Copy/paste won't work, click it.
84_chevrolet 08-16-2007 09:13 AM
I am planning on doing the hd headlight harness next week and the hedlights a week or 2 later. I just thought they would be more info on this subject? no1 has any before or after pics?
87 STEPPER 08-16-2007 11:05 AM
I have them on my truck but they use a 9006 & 9007 lamp not H4 and the HD wiring isn't required most American made vehicles have a heavy enough gauge wire to handle the extra load but they come with a crossover pigtail to connect the stock harness to the new style lamp.
They are very bright:metal:
Attachment 291091
84_chevrolet 08-16-2007 11:47 AM
87 Stepper where did u get ur headlights from?
xtreme80 08-16-2007 12:47 PM
LBJ
Good article, but for some reason I can't help but think that it would almost be more expensive to go this route than it would to just buy the kit from LMC. I see he made the article before LMC sold the kit, but I don't think it would be worth your time or money to do it.
72C203503ONTHETREE 08-16-2007 03:57 PM
I have the bright lights like thoise in the picture on my 83 El Camino, they use the same style lights. Got them from Autozone, dont need to get them from LMC and pay too much. E bay has a billion version for the trucks to. The wiring is screwed up to, have to change the connector wires around but they work good.
Jim85IROC 08-16-2007 05:20 PM
almost everything I see on ebay has those stupid "city lights" which are just blue 194 bulbs. The LMC versions seem not to have that thing and look a lot more tasteful. How about your autozone lights? Do they have that blue bulb?
87 STEPPER 08-16-2007 10:40 PM
Got 'em form LMC and im very pleased with the fit and the quality of the light housings they have a cast aluminum reflector and clear real glass lense.
I don't remember what i paid for them and i dont know how good the ones are from Autozone but what ever i paid it was worth it cuz there a quality piece of equipment.
84_chevrolet 08-16-2007 11:16 PM
Thanks 87 stepper, I will be ordering a hd headlight harness 2morrow and their headlights in the next week or 2 when money allows
Roper 08-17-2007 01:55 PM
There was a thread on here not so so long ago about those LMC Euro lights. Gosh that guy was having troubles! After reading that thread I sure wouldnt buy any Euro lights from LMC
87 STEPPER 08-17-2007 08:02 PM
3 Attachment(s)
Heres the befor and aft pic's i was able to find them.
Befor Stock lamps
Attachment 291396
1/2 Euro 1/2 Stock
Attachment 291397
After Euro lamps
Attachment 291398
72C203503ONTHETREE 08-19-2007 01:13 AM
The Autozone lights dont have the city lights but they have leds around the edges so it glows a light blue when the parking lights or lights are on, its not very bright like the ricer neons though. They also can be left unhooked up to not use them, or they sold a set that didnt have the surrounding lights. The lens is glass and the backs metal. I used the brightest bulbs I could find, very bright and not blinding with the proper angles in the glass. I think I spent between 50 and 60 bucks.
Zoomad75 08-20-2007 11:49 AM
I wrote the majority of the article up on the 73-87 site. If you know what you are doing with electrical stuff, it was cheaper in the long run to do it myself. Two rolls of wire, two relays, two inline fuse holders, weather proof crimp on connectors, some solder and shrink wrap and your done. I had less than $20 in supplies, a lot I already had in the garage. Once I figured it all out it didn't take very long at all to make up the power circuits for the relays and crimp on the connectors to the existing wires where I cut them for the control inputs to the relays.
It just really depends on your skill level with electrical or the amount of time you have to spend on this mod. I'm pretty good with it and at the time, no other kit was available. If electrical is not your bag, get the LMC kit. It's still fairly cheap, but you do have to deal with instructions in Chinese/Japanese. Plus as I've commented about the LMC kit a hundred times (it seems like) the kit does not have ANY fuse protection on it. This means the power wires that are rated for 30amp load have zero protection against a short to ground. If either circuit gets grounded before the load, instead of popping a fuse, the wire will burn up like a toaster element, which could lead to your entire truck burning to the ground while you watch it.
Nobody's chimed in recently that have bought the LMC kit to say if they started putting fuses on the power circuits. I'd be interested to see if they corrected this oversight or not. Heck the instructions might have some warning about it, but my ability to read chinese is pretty poor.
Bottom line, if you get the LMC kit you still should be doing some minor stuff to install the fuses.
84_chevrolet 08-21-2007 09:42 AM
Hey guys thanks for the info, I will be ordering the lmc kit this week and WILL be putting fuse links inline if it dosent have any. I am going to upgrade the alternator this week also the one on the truck has seen better days, the regulator is sticking in it.
SulphurDave 08-22-2007 12:53 PM
Was it mine?
This is my thread on these products with lots of pics and diagrams:
http://67-72chevytrucks.com/vboard/s...d.php?t=247888
I still can't get the high beam lights to come on but after reading these:
Someone needs to please elaborate on exactly what was done here with changing wires around so I can try that with mine. Thanks.
77 350 Shorty Wide 08-22-2007 02:01 PM
Hi Dave,
First thing I would like to say is that this worked on "my" wiring harness it may not work on yours.
I started off by making sure the ground was good and I had the correct wire(s) for it. In tracing this, I discovered the LMC harness ground wire was blue with a white stripe. I then traced that back to their supplied connector the one that plugs into the old factory connector and I noticed it the LMC harness connector did not match up (pin position) with the factory connector. I did this be checking the schematic in my factory service manual. Once I matched up the ground circuit wires (pin) position correctly. It was a fifty fifty chance that the position of the two power wires would work.
My first test try was the same. High beams on when indicated switch to lows nothing. I swapped around the two power wires in the connector (pin positions) & voila worked the second time perfectly.
Basically they had it wired backwards.
Hope this helps. God Bless, Terry
77 350 Shorty Wide 08-22-2007 02:04 PM
By the By, I want to say I Love your truck. God Bless, Terry:)
Also forgot to say; that my truck is a 77 with single round headlights!
