driveshaft loop crossmember
has anybody cut off and reinforce the bottom of this crossmember so it is level with the bottom of the frame? If so, pics and advice would be great.
josh |
Re: driveshaft loop crossmember
I installed the one from Early Classic, very nice peice.
Same here, EC, $199. Looks great, good function as well.
2 Attachment(s)
Check out fletch4x4's thread - 4-link and a turtle... LINKY
I think he did a good job on his. Here's a couple of pics. |
that is exactly what i was looking for. he did a nice job on that. thx for the link.
That's on my to-do list too. Already moved the hoop up. Just need to flatten the bottom. Why not go with the ECE piece? Because I'm not doin a body-off... yet.
When I take this crossmember out to modify it, do you think I would need to brace the frame there at all if the truck is on jack stands with the cab off?
Couldn't hurt.
How high can you raise the top of the loop before it would hit the cab floor? Mine will not be as low as some, so not worried about the bottom but want to run a 1 piece drive shaft so need the room on top. Don't mean to hi-jack just trying to get more info. for all.
Thanks Jack |
Thanks, I read that whole thing and the only # I found that would help me was 7" from bottom of frame to bottom of floor. Only problem is I have 8" from bottom of frame to top of stock drive shaft loop:confused: Of coarse my cab is on the ground, That is why I ask.I guess I will have to take out my tape and do some math.I think my body mounts are long gone, Anyone know how tall they are? Trying to get all the welding done before I put the cab back on.
Thanks for the help. Jack |
