-   The 1969 - 1972 Blazers and Jimmys Message Board (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=36)
-   -   Let the sheetmetal repairs begin! (https://67-72chevytrucks.com/vboard/showthread.php?t=256886)
Musclerodz 09-04-2007 01:56 PM
4 Attachment(s)
Delivered the Blazer this morning to its new home for the next several weeks. If it doesn't rain tommorrow, it will be blasted to bare metal and repairs will start. I will update this thread as progress on the repairs are made. Here is a few pics: new home, more panels from Tri-Plus, and rocker supports from WES.
Mike
Yukon Jack 09-04-2007 02:33 PM
Re: Let the sheetmetal repairs begin!
I will look forward to the updates!
jkaylor68gmc 09-04-2007 02:44 PM
Awesome! Do you have a rendering for it yet?
Musclerodz 09-04-2007 03:54 PM
I decided not to spend the money for a rendering on this truck being a striaght foward rework for the most part.
Mike
LUV2XCLR8 09-04-2007 04:24 PM
Subscribed :D
jkade 09-04-2007 04:54 PM
I notice no bracing to keep everything straight, or is that what the table it is on is for?
vtblazer 09-04-2007 04:56 PM
2wd or 4wd?
What are the plans for it?
Motor/tranny/drive-train etc.
Musclerodz 09-04-2007 06:08 PM
Table is picking up 6 of the 8 mounts. It will get braced before cutting begins
Mike
Musclerodz 09-04-2007 06:09 PM
Originally Posted by vtblazer (Post 2342023)
2wd or 4wd?
4wd, LT1 from '95 Z/28, 4L80E, 205, posi 3.73 front and rear, 18x10 wheels, 33" tires, 2" spring lift up front, 4" shackle flip out back
Mike
badpeanut 09-05-2007 01:30 AM
Clutch type (Eaton, Auburn, etc.)? Dana 44 front axle and 12-bolt rear?
Subscribed!
Musclerodz 09-05-2007 12:01 PM
Subscribed!
Clutch posi, original type, considered tru trac, but found good deals on good original posi's. 44 front, 12 bolt back
Mike
Musclerodz 09-07-2007 11:12 AM
5 Attachment(s)
Tub is blasted. Most of the rot I knew was there, found a few more spots i am going to have to deal with but nothing major I didn't already know. Here is a few pics showing some of the rot, unfortunately there is more. Enjoy my misery:(
LUV2XCLR8 09-07-2007 01:49 PM
Keep em coming :cool:
72BlckButy 09-07-2007 01:52 PM
:agree: keep those pics coming!
So far so good on the blasting/metal work.
Keep us posted!
arkracing 09-07-2007 07:33 PM
doesn't look too bad (although I'm used to rot up here in the North East)
Any Idea what type of media they used to blast it?
vtblazer 09-08-2007 07:39 AM
Blazers do have an amazing talent for hiding rust. :(
Nice to see another one on the mend! :metal:
Luba 09-08-2007 08:44 AM
How much did it cost to blast it? I need to have mine done.
msgross 09-08-2007 09:24 AM
ditto and what media did they use? thanks..
1970cstblazer 09-08-2007 11:13 AM
The Arizona body that I bought for my '70 has outer and inner rocker rot, but that is it.
LUV2XCLR8 09-08-2007 11:32 AM
I guess I'm blessed with ZERO rot, on one of them anyway ;)
Musclerodz 09-08-2007 04:04 PM
Used silica sand or glass, don't remember, probably about #4 grade. Almost a cabinet finish. It won;t require any metal finishing before primer can go on. I am using a product called Blue Lightning Metal Prep that is a phosphate conversion coating that will keep bare metal from rusting up to one year. I would normally call BS, but my '68 Camaro has been in bare metal almost 3 years and is just now starting to show signs of small spots of oxidation. Cost was $350 for the top and bottom of the tub and the tailgate. Rate is $100/hr. which is par for a good media guy in this area. I am on the hunt for a bed floor if anyone knows where a perfect floor is. I will be posting in the classifieds so reply there if you know of one.
Mike
onetonk5 09-08-2007 08:48 PM
That would be the one you want to get rid of??
LUV2XCLR8 09-08-2007 10:51 PM
:lol: Yea, insane huh? :crazy:
Musclerodz 09-24-2007 04:41 PM
I will be posting pics here in a couple days. Work was just started on it over the weekend. Firewall is mostly done and starting on the rocker areas. Found on the driver side the cab floor support half gone so I had to order that and waiting on it and a couple other pieces to get here hopefully late this week. Looking good so far.
Mike
Musclerodz 10-02-2007 03:33 PM
3 Attachment(s)
Finally some pics. Firewall is done, "A" and "B" pillars repaired, kick panel repaired, and inner rocker structure repaired on the right side. Outer rocker is rough fitted waiting for the doors to be hung for final fitting. Right side should be finished this week and starting the left side next week. Right now the truck is filler work until they finaish a '69 Z/28 Camaro that is ahead of me in the shop so progress is slow for the next week or two. Enjoy!
