-   -   Backspacing question - 4.5/6 drop, 17" Torqu Thrust II's (https://67-72chevytrucks.com/vboard/showthread.php?t=257855)
glock35ipsc 09-11-2007 10:10 AM
I was hoping someone had close to the same setup as I am thinking of going with. I'm looking for what backspacing will work for this setup:
Front - 17x8 Torque Thrust II's, 4.5" drop (spindles & 2" springs), stock A-arms
Rear - 17x9.5 Torque Thrust II's, 6" drop (5" springs & 1" blocks)
It seems the rears are only available off-the-shelf in 5" BS (custom available for $$$), but the fronts I have seen 4", 4.5" (Eagle 211's), and 5".
If you are running the TT II's or American Eagle 211's on the front, and they are 8" wide, with a ~4" drop, what backspacing are you using?
Thanks!
