-   -   Grounding strap (https://67-72chevytrucks.com/vboard/showthread.php?t=260175)
my70chevyc10 09-27-2007 05:21 PM
Grounding strap
I just bought a 12 in grounding strap and i would like to know where it is conected to? Engine to firewall or engine to frame my batterys neg cable is conected to the frame any help will be good any pics of engine compartment ground straps would be good to :bling2: :bling:
cdowns 09-27-2007 06:03 PM
Re: Grounding strap
from the factory they had 2small gauge grounds from the firewall one to each valve cover and a heavy one from the frame to the engine also the rad core support to frame the bottom of the cab to frame and from the box to the frame // i'd suggest those as a minimum
i like grounds and run extras and dont have many electrical problems either
Longhorn Man 09-27-2007 10:41 PM
Re: Grounding strap
I would relocate the ground cable to the engine. that's where the mega amps are needed... at the starter.
I would then run the strap you just got from the engine to the frame.
You can now run small straps from body parts to the frame.
ChevLoRay 09-29-2007 09:51 PM
Re: Grounding strap
Some of those small straps were as much for radio interference issues as anything else. The large ones are obviously for the electrical needs of the vehicle. Lots of the small ground straps have been eliminated by folks who just didn't understand the reasons for them being included in the first place.
