Header Gasket advice - Which ones are better?
I'm going to be putting in the new exhaust this weekend but i cant seem to find a good gasket. I need thicker ones .... THAT DONT LEAK! I'm tired of damn header gaskets that blow out. So i bought some locking header bolts and now all i need to know is what you guys think i should use for gaskets.
They need to be thicker .... please if you have some time to point me in the right direction i would be thankfull. Gaskets are for 350 sbc. If you have some pics that would kick a$$ ... thank you -Hart |
Re: Header Gasket advice - Which ones are better?
I use copper.....they are thin.....but they won't blow out......and they are re-usable if you have to remove headers for some reason.
A.......... |
I was looking at those also but i think those will be too thin for my set.
This is killin me .... lol |
I used Percy's Carbon gaskets, they seem to work just fine
Do you know about how thick they are?
Just go buy a set of exhaust manifold gaskets & your troubles will be over. Thats all Ive ever had any luck with on small blocks...
copper is best you can get
I like these the best.. always seal tight and last.
http://www.holley.com/99150AFLT.asp |
No mill work. The headers are round port and they stand out a little bit from the flange so i think thicker ones will be better. But if you guys think otherwise?
I've heard copper is good but I haven't tried them yet.
If you are going to use regular gaskets try one of two things. Either soaking them in water and or vegitable oil first and then put them on. They'll swell up and adhear to your ports/header primary tubes. |
there supposed to stand out, its how they get a sealing surface. do you go back and retighten them several times after you get them hot ?
Well with the old ones yes. But these are the new ones i am putting on that i want to go thicker with.
I think i am just going to go with some basic gaskets and the the lock nuts and see what happens. Keep the advice coming though so more people can read this and hopefully get something out of it. I will post pics this weekend with some sound clips of the open headers before i put the mufflers on :metal: |
try these
http://www.holley.com/99150FLT.asp |
it took a while,but I am a believer in copper now.
Cut the flanges of the headers and get a set of mainfold gaskets and be done with it.
I agree with CORN & Mudder on this. Cut the flange between each port. (But, not thru any mounting holes!) And get you some cheap A$$ manifold gaskets. Take a quick run and tighten again. Works great!! Prolly due to less combined flex - each tube can flex individually. - Dave Like this... |
