-   All 4x4 Tech & Off Roading (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=30)
-   -   Drilling a leaf spring, would ya? (https://67-72chevytrucks.com/vboard/showthread.php?t=262608)
cobinder 10-15-2007 11:11 AM
2 Attachment(s)
I've put my 80 GMC K20 chassis under an old 49 International truck body. The front wheels need to move about 2-1/4" forward for the 39" Michlins to be centered in the wheel openings. I don't want or need any lift. Is it a sin to drill new mounting holes in the leafs? There are only two leafs in this spring. This truck is a city looker/snow driver. She's too hard to find body parts for to go off-roading.
Bishops Trucks 10-15-2007 11:35 AM
Re: Drilling a leaf spring, would ya?
I would say as long as you keep the drillbit lubed and cool while drilling, it shouldn't be a problem. That is going to be one sweet ride.
hilbilly 10-15-2007 02:25 PM
no problem, done it quite a few times. mostly to enlarge the center pin hole so they will accept longer pins.
Yukon Jack 10-15-2007 03:16 PM
You have got to post more pics of that truck - I like it alot!
Take your time drilling those holes as that is some hard steel!
abebummy26 10-15-2007 06:43 PM
Binders are sweet:metal::cool: my old man's first truck was a 61 b110 or b100 I cant remember which
cobinder 10-17-2007 07:10 PM
5 Attachment(s)
Thanks guys for all the help. It's very cool that even thought my truck isn't a full blooded Chevy or GMC you still show me the love. I don't have many pics because my shop is so small I can't get far enough away to take a pic worth a damn.
But heres a few.
Remote control electric tilt front clip.
330 hp 350SB mates to a NV4500 5 speed
62 piece Stainless steel grill
I had to move the steering to the inboard side of the frame rail. The old truck is more narrow then a mini truck and I hated the idea of the steering shaft going through the inner fender wall.
earl87gta 10-18-2007 12:26 AM
That is a way cool truck.
abebummy26 10-18-2007 02:32 AM
My machine tool instructor bought a 35 2&1/2 ton that he is going to make into a rat rod Its gonna be sweet.
Yukon Jack 10-18-2007 10:29 AM
The front end of that truck brings a smile to my face - very cool looking!
cobinder 10-18-2007 12:10 PM
I drilled the springs last night and they drilled out pretty easy. I guess it stands to reason spring steel has to flex so it can't be too hardened.
bdozeraz 10-19-2007 02:20 PM
I have drilled the springs on a couple of mine with no problems. The thing you want to watch out for is if the old pin whole ends up where it is not still sandwitched between the spring pad and top plate. If it ends up right at the edge of the spring pad you stand a real good chance of the spring breaking right there.
cobinder 10-19-2007 05:22 PM
I agree bdozeraz. even when I drill mine it still is at least 3/4" on the mounting perch on the axle and under the spring plate on the top.
