Look what I found
Took my first trip to the junkyard and almost immediately found this lying on the floor of a truck. Got it for $50 with a bunch of other stuff thrown in.
How hard is it to find these? I searched every truck in the yard and couldnt find one with a tach |
Re: Look what I found
Sweet find!
You scored a home run on that. I have only seen one actually installed in a truck. See them on Ebay in the $100-300 range on a freqent basis.
I guess I need to go visit my uncle more. It just hit me he's had a junkyard business for over 50 years in East Alabama. That is a great find :c2:
It doesnt work , I left it there and I would hate to see you lose $50 so i will gladly send you the $50 and you can send me the tach dash .
Just kidding . That is a great find since the font is for the later trucks and it is in nice cond . I bet $250 on ebay all day long . Frank |
You just don't find them things that easy anymore that one looks to be in very good condition except for the plastic film thats missing under the tach. Did you get the tach wiring harness too? |
Nice score. Looks like it is in great shape too.:metal:
I have the same one in my truck, but the tach is off alittle. |
Thats all thats on the back of it
Now im not sure if i should sell it and use the money for my cars or keep it and put it in a truck someday.:D The guy at the junkyard said it was for a 1982 or earlier truck so it wouldnt fit on mine. |
I also found a 1975? Chevy Custom 10 with a 8ft stepside bed 4spd.
There was a lot of great stuff in that yard but unfortunately they are WI cars and you can really see that. |
Where is your Uncles junkyard? |
3 Attachment(s)
Here's the correct one in my 77. |
The guy at the junkyard said the wiring on it wouldnt fit an 1984 Truck.
so I dont really know what its for |
1984Silverado4x4, the cluster you've got (nice score, btw!) is from an '80 or newer. I'm not sure if anyone really knows, but I've read they're believed to have been dropped from the options list after '81, so it would be from either an '80 or '81 model truck. The unleaded fuel gauge would indicate a half ton or light duty 3/4. Even though your truck is an '84, with a little creativity you can make the tach cluster work in it. I just put one in my '89 Burb. |
given it has the unleaded gas like mentioned and the od indicater easily an 82+. i've only ever seen one and that was in my 82, first truck i ever owned and that was like 15 years ago. alot rarer and worth more the earlier years, ive had 4 or five of them.
Good find for 50 duckies
Was it 76 or 75 that had the amp gauge? |
The boneyard find is 1980 up. real good score if it works or not, but since it has the pigtail wires just hook it up and see if it works then check against a REAL tach because those things commonly worked,but were way off as the electronic pieces aged. if it's just off by 100-300 from a good, high dollar tach that's normal. crossy
How and where do I hook it up? |
See the shift indicator with a overdrive position ? 82+ for sure.
You scored big time on that. Weird that someone left that there but it looks like it's in nice shape. I would go back to that same truck and see if you can score the tachometer wiring as well, since it's also an important part of the swap. |
on the picture of the back of the cluster theres a rectangular spot to the right of the speedometer, it has a lot a contacts on each side, does anyone know what goes there?
It was on the floor of a truck that still had the gage cluster in it so I dont think ill be able to find the harness for it. |
That'd be where the main instrument harness plugs into the cluster.
