-   -   81-87 dash pad in 79 ? (https://67-72chevytrucks.com/vboard/showthread.php?t=266752)
cptn60 11-16-2007 02:52 PM
Hi folks. I was wondering if a pad from an 81-87 would fit and work in my 79. Found a perfect pad to match my interior color in the JY for $25. Thanks for the help in advance!
bigblock73 11-16-2007 03:07 PM
Re: 81-87 dash pad in 79 ?
Yes it'll fit, I have a 81+ in my '73.
old Rusty C10 11-16-2007 05:36 PM
the only problem will be that if you have a 79 the vin tag should prolly be on the door pillar whereas on the 81-87 it was on the dash.. If it bothers you you will notice the original cab color through the windshield where the dash panel has the hole.. you can prolly cover that easy enough tho
Jonboy 11-16-2007 05:51 PM
79-up have the VIN on the dash. It may even be 78.
bigblock73 11-16-2007 06:55 PM
79 up are on the dash
low sierra 11-16-2007 07:34 PM
For those interested I have put the early, 79 pad in the 81 cab that I have installed on my 79 chassis. The dash is the same except the 81 has provisions for small speakers in each corner. 81 pads and above are shaped different on top and have provisions to allow the sound out of the speakers.
cptn60 11-18-2007 01:56 PM
Thanks, Guys. Lots of real nice folks here:c2:
smashingchuck 11-18-2007 04:09 PM
Originally Posted by bigblock73 (Post 2448784)
78 up are on the dash
my 78 has the VIN in the door??
bigblock73 11-18-2007 04:18 PM
typo on my part, meant to back up what Jonboy said...79+ are on the dash. Sorry.
smashingchuck 11-18-2007 04:48 PM
had me worried there for a minute. I know my truck is hacked up, but...
