Will 3/4 ton front susp. fit the same as 1/2 ton
I found someone that has 3/4 ton front suspension for my blazer conversion project for free. I would use air ride suspension for arms etc... Will this fit the same as a 1/2 ton? What problems might I encounter, is it worth it?
Re: Will 3/4 ton front susp. fit the same as 1/2 ton
What year is your truck? Ball joint sizes have changed over the years 3/4 ball joints are helpfull when going to later model disc brakes. Add some info maybe we can help. Rob
Sorry, The front end is off a 72. I am installing it on a 71.
