-   -   69 c-10 with 3 speed manual with OD? (https://67-72chevytrucks.com/vboard/showthread.php?t=267415)
loony.toon 11-21-2007 08:27 PM
I have a chance to pick up a 69 c-10 with an overdrive manual trans. 3 speed on the column with a pull switch under the dashboard for overdrive. I have never seen this. Anyone know anything about it? good or bad? thanks Ron (a new guy):help:
Huck 11-21-2007 09:26 PM
Re: 69 c-10 with 3 speed manual with OD?
Not common but not really rare either. These 3spd OD trans have been around wince way back in the 40's. The 69 should have syncro's in 2 and 3rd. They are ok for normal operation but don't handle high HP performance applications. I'd love to find one cheap enough to have rebuilt then stick in a 6 cyl truck.
qksilver 11-21-2007 10:02 PM
same here, they are cool and work but not the best for hevay duty use
loony.toon 11-21-2007 10:16 PM
Thanks for the help.
special-K 11-22-2007 09:03 AM
Most o/d gears don`t like heavy hauling or high power.It`s a good ole 3spd w/a n o/d unit added.You`ll get the same service as a 3spd w/o o/d.They are pretty uncommon.I want one,too.
loony.toon 11-22-2007 09:17 AM
SpecialK, I didn't follow you with all the abbreviations. Will it perform just like a regular 3 speed if it is not engaged? Can it go bad? Does it take the whole trans out or can you just not use it? thanks all for the help.
WorkinLonghorn 11-22-2007 09:18 AM
Here's the page from the '69 Data Book;(Hope you can read it)
http://i134.photobucket.com/albums/q...r/IMG_1159.jpg
loony.toon 11-22-2007 09:27 AM
thanks for the help. This particular one is working well. The truck is for my son who is 18. He is more interested in it as a street rod. If anyone is in need of this tranny, I would be willing to part with it for a 3 or 4 speed. You would have to do all the work including converting it to the floor. It would be an even swap. thank you all for your help.
berencam 11-22-2007 11:55 AM
i also had the 3 speed manual with od.... and honestly all the difference i noticed was when it was engaged(or disengaged...i never figgured it out) the engine would either be locked harder to the clutch or it would act kinda like a auto tranny. To where when you let off the gas, it would let the engine free from the tranny as if you where pressing the clutch in. Furethurmore, if it was engaged when you let off the gas you could shift without pressing the clutch regardless of speed or rpm. i hope that made since....
Botietruck 11-22-2007 06:07 PM
'69 was the last year Chevy put them in the trucks. Most of them used the 3 spd. Saginaw with a Borg-Warner overdrive unit. You can use the trans. without engaging the OD. Parts are hard to come by and they are expensive, they're out there, thanks to Ebay, but expensive. Here's one I just rebuilt. The 7 bolt side cover is the syncro trans.
http://i6.photobucket.com/albums/y24...esopics040.jpg
WorkinLonghorn 11-22-2007 08:23 PM
So that little lever in the back actuates the overdrive? Apparently you could use the OD in any gear and it was a freewheeling type of thing if you let off the gas. I wonder how much torque it was rated for.
Don Brace 11-22-2007 09:08 PM
I put one of these in my one ton 71 Longhorn. It is behind a 350. I love it. I get 14 or 15 MPG on the highway at 65 MPH. It town I average 12.5 MPG. When hauling a heavy load I lock it out of OD so as to not trash the OD unit.
vrwelker 11-25-2007 09:41 AM
sent u a pm. interested in the trans u have.
Don Brace 11-25-2007 12:55 PM
Have not received your PM. The OD in the truck is not for sale. I have several
car ODs. These have a higher 1st gear than the ones for the truck. You also must use a car bell housing. The truck bell housing has two threaded holes and two that are not threaded. The car bell housing has all four holes threaded where the OD attaches to the bell housing.
Don
67ChevyRedneck 11-25-2007 03:07 PM
Wow, final ratio of .7:1. That's equivalent to a 700R4.
