No front turn signals with headlights on
What could be wrong turn signals work fine when headlights are off but when you turn headlights on only side markers in front blink
Re: No front turn signals with headlights on
bad ground check them connections
Sounds like a bad ground or maybe some sort of short.
If it isn't a ground, it is possible to be a turn signal switch. but not likely!
Could be a bad bulb
