-   -   clutch plate position (https://67-72chevytrucks.com/vboard/showthread.php?t=273973)
prg machine 01-13-2008 06:28 PM
kind of a dumb question..but if you're not sure ask.right??
the friction plate for my small block.............simply put,,, which way does it fit against the flywheel??
with the part of the disc and springs that is the tallest in the center away from the flywheel or towards it..???????????????
thank you.
The splines have a taper for the engagement on one side for the trans input shaft,, I asume this goes towards the transmission......
prg machine 01-13-2008 07:27 PM
Re: clutch plate position
ttt
crazy longhorn 01-13-2008 07:55 PM
talllest part in the center toward the trans......
LONGHAIR 01-14-2008 05:07 AM
Yeah, what he said ^^^
prg machine 01-14-2008 05:26 PM
Makes sence afterall.. that 's where the lead in is to the splines... for tranny shaft..
all of the books say "side marked flywheel side towards flywheel" which in my case there is nothing marked.
Thanks again guys...........it's great to have a second opinion..;)
