-   -   Factory, OEM carpets?? (https://67-72chevytrucks.com/vboard/showthread.php?t=274865)
James McClure 01-19-2008 09:13 PM
Hi everyone. I got a carpet from LMC and put it in yesterday only to find out it is about 2" to small side to side and it looks like crap. I don't know if it will stretch out once the weather warms up but if I can find a source for a GM OEM carpet the LMC one is history and will go into my other truck.
The LMC carpet is thin at best. I don't like the quality at all. If someone knows a source for good carpets, OEM or not, please let me know. Many thanks, jim
bigblock73 01-19-2008 09:47 PM
Re: Factory, OEM carpets??
ACC is the best IMO. CaptKaos (Chris) is a vendor and sells it.
N2TRUX 01-19-2008 09:51 PM
That's your answer right there...:metal:
72freak 01-19-2008 10:35 PM
Make sure you got what you needed..........high hump, low hump...that might explain it being too narrow.
ACC is the way to go. You cn deal with them directly
Captkaos 01-20-2008 03:10 AM
I sell ACC carpet, it is listed here, they are 126.95 + 21 shipped...
http://store.73-87chevytrucks.com/me...ory_Code=FLRNG
James McClure 01-20-2008 05:51 AM
Chris: Thanks man. I will probably be in touch with you when money permits. The carpets you sell just like factory OEM? I worked for GM for 33 years and from what I read above there is a high or low hump?? Danmed if I know. It's an 84 regular cab with a 4 speed manual trans and 4 WD, that make a difference? I never noticed to tell the truth. I never did a bunch of inside work on these things. I was always into the greasy parts, LOL. Thanks, jim
bigblock73 01-20-2008 05:55 AM
Jim, you have a high hump trans tunnel
lolife99 01-20-2008 07:29 AM
So you probably have "low hump" carpet. I think that's the problem. Hopefully you can return it!
chev74 01-20-2008 08:32 AM
i got my carpet this year from LMC for my 64 man tranny (on the floor)- ordered the high hump, but there seemed to be extra fabric/ lots of slack at the seat side of the hump. is the LMC carpet fro ACC??
tyjoja 01-20-2008 11:44 AM
I have a 73 1/2 ton that was originally 3 on the tree, that needs carpet. sounds like captn kaos is the way to go, do you know if mine is a low or high hump? thanks bob
old Rusty C10 01-21-2008 01:24 AM
2wd is low hump 4X4 is high hump
jeez capt you havent got enough colors to choose from LOL (kidding)
Restrorob 01-21-2008 02:42 AM
Hey Captkaos,
I see your carpets are from the seat forward, Do you have full coverage or know of a supplier for a quality full coverage (low tunnel) carpet ?
chev74 01-21-2008 10:09 AM
i think 2wd floor shift is high hump though. my dads was a 2wd column shift and his hump is definitely smaller
James McClure 01-21-2008 09:14 PM
I am going to have to figure this out somehow, mabey measure hump height or measure from floor flange to floor flange across the cab over the hump. Mabey just get the carpet for a high hump and cut off the excess at the doors. I do know I want full floor coverage, up under the seat and all. Chris, you have such s critter?
BLE 'BURBAN 01-22-2008 04:53 AM
Those of you with a "HIGH hump" measure your hump hiegth and post it here for all to see
Those of you with a low hump lets do the same so we ALL will know the difference. I'm going outside to measure mine right now to see how high it is.
bigblock73 01-22-2008 06:43 AM
2 Attachment(s)
Here is a low hump (on my '73)
Restrorob 01-22-2008 07:03 AM
Mine measures 5" from the floor to the red line as on Jeff's, That's without carpet/insulation, 2 wd auto.....
