-   All 4x4 Tech & Off Roading (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=30)
-   -   Transmission Crossmember for 4x4 (https://67-72chevytrucks.com/vboard/showthread.php?t=276570)
Rat72 01-31-2008 02:41 AM
I'm looking to replace the transmission crossmember on my 72 K10. Is anyone running an aftermarket transmission crossmember for their 4x4? How's the fit and who made it? Are the 2wd and 4wd crossmembers the same?
Thanks,
Whit
duallyjams 01-31-2008 08:01 AM
Re: Transmission Crossmember for 4x4
whats wrong with the one you have?
Rat72 01-31-2008 12:24 PM
It's flimsy, it sits about 2" lower than it needs to and it takes up a lot of room that I would like to have for the exhaust.
duallyjams 02-01-2008 08:22 PM
You would either have to do it or have someone custom fab one.
hilljob26 02-25-2008 09:51 AM
i think i have an extra,pm me if ya want
OLDCHEV4X4 02-26-2008 05:39 PM
It sounds like you have the wrong crossmember. On my 205, the transfercase is lower than the crossmember. Do you have a body lift?
Rat72 02-26-2008 09:13 PM
No body lift any more but I am running an Atlas transfer case tucked up high for clearance. However, even with the 205 which did hang below the crossmemember, there were dings on the crossmember from the previous owner. I guess he was lucky he didn't rip out the transfer case.
Rat72 02-26-2008 09:15 PM
Thanks, I appreciate the offer but I think I am going to build a skid plate which will include the crossmember.
