-   All 4x4 Tech & Off Roading (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=30)
-   -   Trans-transfercase coupler. (https://67-72chevytrucks.com/vboard/showthread.php?t=280146)
79oldj 02-25-2008 01:00 AM
Was wandering if anyone new of an aftermarket part to replace the sleeve between the trans and tcase on a 4speed np205 setup? This seems to be a weak link in an otherwise bulletproof setup.
1969 GMC 02-25-2008 01:55 AM
Re: Trans-transfercase coupler.
Did you try the dealership? I thought I had read somewhere you may still be able to get it new.
Aside from that, you have to find a used one, or have one made ($$$). I would just find a later model 32 spline pair instead at that point.
79oldj 02-25-2008 06:51 AM
The one I have is not broken, but I know from previous experience this is the first/only thing that seems to break when you put serious amounts of torque through a 4 speed 205 setup. I was wandering if there was an aftermarket part to strengthen this part of the drivetrain.
eric67m 02-25-2008 07:29 PM
I recently googled "10 spline coupling", because my truck has massive slop when you get on and off of the gas, and found...
http://www.extremegearoffroad.com/st...cat=434&page=1
http://quad4x4.com/GM%20Transfer%20Case.htm
Both are $80-85. The one from quad says its made in the USA.
Hope this helps.
Ace in the hole 02-25-2008 09:54 PM
just bought a new one a few months ago from anaheim gear, very good people to deal with. I think it was like $60
http://www.anaheimgear.com/home.html
