rear axle
what rear axle would my 60 4x4 1/2 ton have in it
Re: rear axle
GM corporate HO33 I think is the model. Smaller version of the HO52/HO72 corporate axles that were still used until '72.
Re: rear axle
whats the difference between the HO52 and the HO72 these were the big Eaton 12 1/4 units werent they
Re: rear axle
Pretty much the outer stuff:brakes and hubs.The HO72 will have a pinion side thrust adjustment,too.Not sure if it`s all or whether some HO52s did,too.If memory serves,all HO72s did and some HO52s did.
Re: rear axle
the 12.25" ring gear is the H110, optional on C/30's only. They had 10 lugs in the rear, 5 up front with this axle. |
Re: rear axle
Whats the ring gear size on the HO52/72
this is the diff I got in my 67 |
Re: rear axle
Its roughly 10-1/8" when I hit mine with the tape measure
