-   Suspension (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=25)
-   -   Do I have a posi or locker?? (https://67-72chevytrucks.com/vboard/showthread.php?t=281938)
thelonerife 03-07-2008 06:11 AM
I have a 3/4 ton 10 bolt rear. I would like to know if it is a posi or locker. I took the cover off and it doesn't look like other posi's I've seen on 1/2 tons or cars. Looks like it has smaller spider gears next to the ring gear. When I have both wheels off the ground and turn one the other goes th same direction. Also when I lost traction in wet grass it left two tire tracks. I would post pics but haven't figured that out yet.I was told by po that it was a 4:10. Any help would be greatly appreciated!!Chuck..
slammed1 03-07-2008 07:24 AM
Re: Do I have a posi or locker??
True LOCKERS arent the norm for street vehicles so you most likely have a posi style rear differential.
Posi,Limited Slip,and other names are used for basically the same style of rear differential unit.
gringoloco 03-07-2008 08:13 AM
An open diff will have spiders too. Look for a spring loaded clutch pack in the middle of the carrier, between those smaller spider gears.
thelonerife 03-08-2008 04:32 AM
Okay thanks guys!
thelonerife 03-11-2008 01:32 AM
Here a pic of what looks like.
slammed1 03-11-2008 05:50 AM
That is a Power Lock (just another name for a POSI) in a Dana 44 or (most likely >>)a Dana 60 from what I see. The "PowerLock" had a 2 piece case with 4 spider gears and 2 side gears and a "TracLoc" had a one piece case with 2 side gears and 2 spiders. Both units use clutches and plates for the posi operation.
slammed1 03-12-2008 11:52 AM
Did you get your info needed?
thelonerife 03-13-2008 05:23 AM
Thanks I had no idea what i was looking at and it acted like- I always have heard- a posi does and the glovebox had no indication of this kind or rear. Thanks for all of you guys help!!! Chuck.
slammed1 03-13-2008 07:52 AM
I think Dana rears in these trucks are cool. I built a narrowed Dana 60 for my street/strip Nova before I sold it..........it had a Power Loc and I bought a TracLoc with 35 spline side gears for better axles.Very strong rear axles......very strong.
thelonerife 03-14-2008 06:11 AM
Well I've just sold this one that was in a rolling chassis from a 72 3/4 ton for 250. So I don't know if I shorted myself or not but I needed to get it out of the yard. The guys coming from the Atlanta area to pick it up so I guess its worth the trip,
