-   -   Leaking Brake Lines (https://67-72chevytrucks.com/vboard/showthread.php?t=282071)
1984Silverado4x4 03-08-2008 06:02 AM
Leaking Brake Lines
I just put new brake lines on a truck but there leaking where I used connectors to connect the lines along the frame rail. I took them apart and couldnt find any defects or dirt or any thing so Im thinking I should just wrap them in teflon tape then put them back together. Yes the the connections were tight. Would this work or does someone have any better ideas?
old Rusty C10 03-08-2008 07:50 AM
Re: Leaking Brake Lines
i never use the teflon tape.. is it possible you didnt have them tight enough? maybe different manufacturers differnt threads??
Blackstone 03-08-2008 05:31 PM
First, tell me you used flared couplings as opposed to compression-style. If flared, did you buy pre-made lines or did you flare them yourself? My first thought is that the lines may not be double-flared.
1984Silverado4x4 03-09-2008 01:44 AM
They are flared couplings and they were pre made and double flared. And they were plenty tight
Blackstone 03-09-2008 02:12 AM
Hmmm... I never had one leak before. All I can think of is to try couplings from a different supplier... maybe a slight manufacturing defect unseen to the naked eye is involved. In any case, I wouldn't trust the sealing qualities of teflon under this kind of pressure. I wouldn't feel comfortable with a fitting that can't seal on it's own... at least on the braking system
