-   All 4x4 Tech & Off Roading (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=30)
-   -   what transfer case?? (https://67-72chevytrucks.com/vboard/showthread.php?t=283692)
griesel72 03-19-2008 04:06 AM
i am going to look at a 1968 gmc k10 with the 305 v6 and a 4 speed, i have been told that it should have the rockwell 221 transfer case, is there any chance it would have anything else? I had thought that it might have a dana 20? or were these only used in early blazers? Is there a sure fire way to tell when i am looking at it?
thanks for the help
David
Livrat 03-19-2008 05:18 AM
Re: what transfer case??
If its a granny gear 4spd it should be the Rockwell T221, I have only seen the Dana 20's behind a 3 spd saginaw.
CRUE's 67 LWB 03-19-2008 09:28 AM
There ought to be a tag on it somewhere. I dont know what years the 205 and 203s started but they are both decent transfer cases if taken care of.
dinotruck68 03-19-2008 04:07 PM
my 68 has the rockwell 221 tcase and the sm465 with the super low 1st gear.. with the axles ur guess is as good as mine cuz im still confused on that 1.i dont think they started using the 205's till 69
special-K 03-19-2008 05:22 PM
As far as what I`ve seen only Blazer w/3spds used the Dana20.The trucks and Suburbans I`ve seen have all had the Rockwell 221 or later New Process 205 no matter what trans was used.
1969K10 03-19-2008 05:23 PM
thanks for the help
David
you should have a rockwell in there. It will be kinda triangular shaped. the other choise is a NP205 (doubtful), but it be kinda like (2) circle shapes with a connecting portion between them. Yukon has a recent post about finding his leak, with some good pics of both.
duallyjams 03-20-2008 12:35 AM
The np205 started in 1970. The easiest way to tell is the rockwell rear drive shaft will be low , toward the bottom of the case and the 205 will be high toward the top of the case.
Blazer1970 03-20-2008 12:58 AM
They definitely came in 1969 Blazers, but those were more like a 1970 truck than a '69.
Old Chevy Mech 03-20-2008 02:10 AM
My 70 Blazer has a Dana 20 behind the 4speed.
Frank
duallyjams 03-20-2008 02:53 AM
I believe that sometimes when GM had left over parts they kept on using them in next model years until they ran out.
Old Chevy Mech 03-20-2008 06:40 AM
LOL Cant blame them...I've got no complaints!
Hows the weather down there?
Frank
Yukon Jack 03-20-2008 05:32 PM
My 70 K5 also had a Dana 20 behind it's SM465 pursuant to the prior owner. It was gone when I bought the truck but did have a chrome t/c bezel that wouldn't have been used with the NP205. Also, when I put in an NP205 I had to drop the crossmember down an inch so that helps me confirm that it didn't have an NP205 in there to begin with.
