-   -   Lowering Blocks (https://67-72chevytrucks.com/vboard/showthread.php?t=28591)
78SilveradoSWB 10-30-2002 04:58 PM
Lowering Blocks
Any pro's or con's in using a lowering block in conjunction with a flip kit to lower rear to 6"?
BaggedC10 10-30-2002 06:15 PM
I would not recommend using blocks! Just install 2" adjustable shackles and set them at the 1" setting. :bowtie:
78SilveradoSWB 10-31-2002 02:58 AM
LowC10 (Dave)
If I use the lowering shackle, will I then have a problem in using a air lift air bag? :confused:
78SilveradoSWB 11-01-2002 04:29 AM
ttt
Tom 11-01-2002 06:13 PM
There is absolutly no problem using lowering blocks. Heck, thats the only reason Im going with a flip kit is so if I ever want lower all I need is blocks. Shackles require cutting bed supports, hangers require grinding off old rivits. Big pain in the butt.
BaggedC10 11-02-2002 12:39 AM
Originally posted by 78SilveradoSWB
LowC10 (Dave)If I use the lowering shackle, will I then have a problem in using a air lift air bag? :confused:
Nope! :cool:
BaggedC10 11-02-2002 12:40 AM
The proper tools make the job 100% easier! :D
