-   -   Filling trim holes around rear taillights (https://67-72chevytrucks.com/vboard/showthread.php?t=291977)
VA72C10 05-16-2008 09:41 AM
I did search several different searches but found no answers
I am planning on biting the bullet and getting Musclerod's rear lights/bezels. This will require me to fill in the holes for the factory trim. I am having help on the bodywork and want to make sure we do it right. Will it be okay to simply fill the holes with body filler or is there a better way to do it? Thanks!!!
JimKshortstep4x4 05-16-2008 12:08 PM
Re: Filling trim holes around rear taillights
If it were mine, I would weld the holes to fill them in.
Jim
VA72C10 05-16-2008 02:46 PM
Well, i've never welded, but the guy doing the body work is using a wire feed welder. WIll that work okay or warp the metal? Do i just make sure he goes slow and switches sides? Since the holes are so small do we need small patch pieces or just fill w/ the wire? He's done a great job with the other patches, but they were full panels like rockers and cab corners. Just want to make sure the new (old but new to me) bed isn't boogered up. Sorry, noob here....
Madmandav 05-16-2008 02:53 PM
No patches will be needed, just take it slow do a little at a time and it will be fine.
piecesparts 05-16-2008 03:09 PM
Weld the holes is the best way and the most permanent. Use a small piece of metal or a short flat head screw as a backing plate and use the wire feed welder to spot the weld in. Hit the spot with the welder and back away to allow for cooling, then fill the weld as necessary. Using a grinding tool with a flapper wheel or a 3-m nylock pad to smooth and prep for body filler. Ensure that you try to cover the spot on the backside with a good paint or weld primer.
Charlesdur 05-16-2008 04:46 PM
agree... don't use bondo to fill these holes. There is a very good chance that it will pop or show a small defect in the paint over time.
sleepyboy 05-16-2008 04:50 PM
Weld
Charlesdur 05-16-2008 04:58 PM
post pics also. I am doing the same thing on my truck and did some previous research.
VA72C10 05-17-2008 07:02 AM
Thanks everyone....i'll post up pics on my build thread when i get to start working on the truck again.
cstm68 05-17-2008 07:35 AM
there is a pic i my build thread of how i welded them on my truck.
