-   -   Brake proportion valves (https://67-72chevytrucks.com/vboard/showthread.php?t=295247)
orbot 06-10-2008 10:22 PM
Who has used theese, and wich, i have 1/4" lines but cant decide on wich one.
PhilaTruck 06-12-2008 09:18 PM
Re: Brake proportion valves
Can you re-phrase your question?
This is the answer to what I think you're asking. You'll need to know what kind of rear-brakes you have. There were 3 different size drums for all models 80-87. (You don't specify which year yours is.) If you give your parts supplier the RPO code from the inner fender or the glove box, they should be able to get you the right proportioning or combination valve.
This info came pretty much out of a Chiltons, which I recommend. Or a Haynes or whatever.
Lots of good info in idiot books.
Good luck-
-Todd
LONGHAIR 06-13-2008 11:57 AM
Are you refering to an "adjustable" valve? These are an "add-on" thing, they do not replace the original.
COMP 06-15-2008 11:14 PM
some do,, some also have a low pressure check valve
LONGHAIR 06-16-2008 06:56 PM
Link?
COMP 06-16-2008 07:42 PM
Originally Posted by LONGHAIR (Post 2768012)
Link?
summit,,jegs,,speedway automotive etc ,,the street rod supplyers to
LONGHAIR 06-17-2008 07:27 PM
I looked it up in Jeg's catalog, yes the paper one....
They do have one like that. I had never seen it before, wasn't really looking for it before either?
