-   -   How to install the vent window weatherstrip? (https://67-72chevytrucks.com/vboard/showthread.php?t=296900)
andresco50 06-24-2008 03:03 PM
Hi guys i bought a new weatherstrip for the vent windows but I can't figure how to install em.. I can't take off the glass?
westie 666 06-24-2008 04:00 PM
Re: How to install the vent window weatherstrip?
You have got your work cut out for this one.
You need to remove the vent window assembly from the doors then you can remove the vent windows and replace the rubbers.
Once the old rubber is out soak the new rubber in hot water to soften it and use plenty of graphite grease and ease it into the track.
http://i257.photobucket.com/albums/h...7_Chev_039.jpg
http://i257.photobucket.com/albums/h...7_Chev_041.jpg
http://i257.photobucket.com/albums/h...7_Chev_042.jpg
http://i257.photobucket.com/albums/h...7_Chev_043.jpg
mhicks 06-25-2008 07:11 AM
It sucks, never could get mine right.
Project82 06-25-2008 10:28 PM
i went through the same problem disassembling the vent window...and i found out i bought the wrong weatherstrip (i needed a 2 piece seal when i bought a 1 piece instead)...first i took the vent window out of the door and started drilling out the rivets (2 on top and 2 on bottom and 2 on bracket that allows window to swing out)...then take the nut off the spring rod, from there on just install weatherstrip and buy new rivets...i should've soaked my seals in hot water but i rushed the project instead...now i have to listen to the air whistle in the seal again...damnit!:bs:
andresco50 06-27-2008 01:58 AM
I hate the rivets
70LonghornCST 06-27-2008 03:03 AM
Originally Posted by andresco50 (Post 2782929)
I hate the rivets
Especially the pivot rivet!
Project82 06-27-2008 03:34 AM
hmm...i never had to touch the pivoting rivet...just the two on the bracket..
GMBowtie79 06-27-2008 02:59 PM
that sounds alot easier than swiching to one piece windows.
Project82 06-28-2008 12:23 AM
Im thinking about getting rid of the vent windows and going with a one-piece window kit...how hard could it be?
GMBowtie79 06-28-2008 03:17 PM
I heard the where a P.I.T.A. to install. do a search there are a few people that have done them. I know that 7T7 has them in his truck. I would talk to him he would probably have more insight on the subject.
andresco50 06-28-2008 05:05 PM
Thanks guys!!! Now I have to install again the rivets:devil::devil:
Project82 06-29-2008 01:34 AM
hmmm...alright, ill ask him...thanks...
you're welcome andresco50...
:smoke:
Captkaos 07-07-2008 02:26 PM
Putting in the 73-87 One piece kit is not that hard. The biggest thing is drilling the new holes. 7T7 got his from me, so he would be a good place to get an unbiased opinion.
