Fuel pump pressure
I have a aeromotive drag pump setup and the pump has a bypass , I was told to set it at 30 psi but it caused the front regulator problems so i dropped it to 20 and it seems to be better.
Do any of you guys have this type of setup and what psi do you run from the pump ? Front reg is at 8 psi . thanks |
Re: Fuel pump pressure
I have been running a BG400 for nine years . I have ran them at 30 and as low as 22 . BG recomends 24 I believe for my pump . I'm sure with the volume of your pump you should be fine .
Thank you sir.
I had to rebuild the carb regulator because of a bad O ring and had a heck of a time getting the right part. Guess Aeromotive doesnt have many problems with their stuff. Anyway thanks for the info. Keith |
I have a A1000 pump with a return reg set @18psi, then out to static reg for my N2O set @6.25 flowing, and another static reg for my carb set @7.5.
