-   The 1967-1972 Chevrolet & GMC Pickups Parts Board (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=8)
-   -   Looking for parts for the brake booster bracket (https://67-72chevytrucks.com/vboard/showthread.php?t=300216)
VA72C10 07-21-2008 07:12 PM
I need the bolt/piece that goes from the hinged brake booster bracket and attaches the rod that goes through the firewall. THe factory one i purchased was missing that. I also need the bolt with the cotter pin that attaches that same rod to the brake pedal under the dash. Hoping someone has extras lying around as i'm having no luck w/ buying a parts truck w/ these items on there and no junkyards near me have our year trucks. Thanks in advance!
VA72C10 07-22-2008 12:18 AM
Re: Looking for parts for the brake booster bracket
ttt
tommypic 07-22-2008 05:03 AM
mine was so rusted I couldnt get the cotter pin out . I am just going to use a pin that you can buy at Tractor Supply .
71stub 07-22-2008 07:46 AM
i have one in my garage let me take a look for ya.
VA72C10 07-23-2008 10:50 PM
THanks. let me know if you find what i'm looking for....if you can post pics of the parts to make sure it's the right ones, that'd be great.
71stub 07-24-2008 10:02 PM
I dont have the bolt with the cotter pin that i can find but i do have the pin with the clip that holds the rod to the lever. Let me know if that helps.
VA72C10 07-24-2008 10:16 PM
THat will help. I think i have one of the bolts w/out the cotter pin somewhere and can just buy a cotter pin. Just to make sure, this is the pin that attaches to the end of the rod that is in the engine bay and passes through the fire wall. The other end of the rod that attaches to the pedal. Thanks.
71stub 07-25-2008 07:28 AM
Thats the pin that im talking about and it has an odd square shaped clip with a tab that holds it in place.
JimKshortstep4x4 07-25-2008 08:09 AM
Here is a picture of the special shoulder bolt that holds the brake rod to the brake pedal. If you still need one you can have it for the shipping costs (not sure what that would be).
Jim
71stub 07-25-2008 11:21 AM
Anybody know where i can get the rubber boot used to go over the rod that goes through the firewall?
byrd 07-25-2008 08:36 PM
You can click on the link below in my signature to get to the board supporting vendors. Any one of them will have the brake rod boot you need.
