-   The 1988 - 1998 GMT400 Chevy & GMC Pickups Message Board (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=12)
-   -   95 GMC A/C Issue (https://67-72chevytrucks.com/vboard/showthread.php?t=300488)
70cst10_05 07-23-2008 10:26 PM
95 GMC A/C Issue
So I have had this 95 GMC ext. cab 4x4 for a couple weeks now. Tonight and a few other nights I have driven around (I haven't put many miles on it) I've noticed some condensation on the windshield right where the defrost vents are. One thought I had was that the blender actuator might not be quite getting off of defrost and to vent, because I had a slight problem with it not turning to vent. I solved this by just pushing it and it has worked OK since then. Anyway I thought that maybe since there is cold air coming out of the defrost vents that it is cooling the windshield and with the high humidity here in nebraska that it is causing some condensation on the windshield. I use the wipers to get it off but it comes right back almost immediately. I was wondering if anyone else has experienced similar problems and had a remedy for it. Thank you for all your input. All help is greatly appreciated. Thank you,
Kevin
70cst10_05 07-31-2008 07:59 AM
Re: 95 GMC A/C Issue
TTT please, this is rather annoying. Thanks fellas
junkman8302 08-03-2008 05:14 PM
This is with the A/C on and set for the center dash vents? Or just with the blower on and set to defrost, because even with the A/C off and set to defrost the A/C compressor will still run and condition the air.
70cst10_05 08-03-2008 08:34 PM
This is with the A/C on and the blower set to the dash vents, but there is still a little coming out of the defrost vents. Any help is appreciated. It doesn't seem to do it unless its dark and really humid.
joe231 08-06-2008 12:34 AM
my '95 suburban does the same, sorry, don't have any input on the fix, but will be tuned in waiting on replys
