custom hood cowl?
a kid from school on his 88+ chevy just cut the hood down the center in two spots from the back almost to the front, lifted it about 4 inches and bent it a little and then welded sides in, didnt touch the braces underneith.. im thinking about doing it? good idea or badd:metal:
Re: custom hood cowl?
Depends
how good are you at cutting fabricating welding and finishing sheet metal ? Mark |
Hot Rod Magazine an article in the 80's with a early model mustang where they cut the hood as you described. They lifted the trimmed pieces up with spray paint lid caps to give the same height. The then used a rolled piece of metal to patch in cutting caty corner to give the same roll on both sides. I know someone on this board talked about it last year, perhaps you can do a search and find it.
WELL THANKS A WHOLE H-E-DOUBLE-HOCKEYSTICK LOT!!!! As if I didn't have enough idea's I can't afford to do, you just went and gave me an idea as to how to set up a RAM AIR OLDS 442 STYLE hood scoop on my burb. JEEEZ!!!! More money I gotta make now!!!!
Where's my scanner/printer at? I gotta get ta printin'....... |
send me some of the money you print.. and ill fill your ink for free :ito:
I’m a sheet metal welder by trade and I wouldn’t do it. The heat warpage will kill you, and if you can’t do the work yourself the cost would be more then one from LMC. The only way I can see it is to spot weld and bondo. If I were to do anything I would cut your hole and fiberglass your cowl in.
Having said that I do plane on making my truck an extra cab for no other reason then I can. So don’t let me talk you out of it. |
i have had this idea for the longest time but warpage and a bad out come worry me but i say go for it and post hella pics.
well idk.. i can get it welded for free (dads works at a garage) so that will be fine..
I would certainly would practice on an old hood first and if that goes ok then do it but i myself think it would turn out to be one heck of a lot of work to get it to look good
I'd like to see some pics or a tech article. cool idea
Good idea but you have to cut it very carefully very straight, and weld it very good... Post some pics of your friends's hood!!!
Jump in with both feet, if it doesn't work, then buy onefrom LMC, but try and save a little $ whenever you can. I'm going to build on for my 64 because I want to keep the "V" on the hood. Besides, a little warpage is nothing a skim coat of bondo won't fix.
2 Attachment(s)
You mean something like this?
skinnyer then that.. like half the size. and 4 inches in the back and im gona leave the front attached and just bend it
ARAMP1, I was looking for the post on that dually on my forum to post it today...
I would only reccame, recomen, recc.... I would only advise the best of body workers to do this... I thought I was pretty good until I tried to tackle that monster... save your pennies, and hours upon hours of spot tacking, grinding, bondo-ing for something that "looks o.k." the further off you are.
http://i7.photobucket.com/albums/y25...ruck1small.jpg |
http://www.stylintrucks.com/parts.as...tfamilyid=3168 i imagined something like this would look sleak as ever
