-   -   tilt hood kits...Any pics? (https://67-72chevytrucks.com/vboard/showthread.php?t=303414)
ed3196499 08-18-2008 07:47 PM
I have been looking at some of the tilt hood kits in mags do any of you have pics or reccomend a certain kit? I have i thought for a design on the hood that would look sharp when the hood is tilted up
dubdeuce80 08-19-2008 02:59 PM
Re: tilt hood kits...Any pics?
get hinges out of an older buick...you can get them from a junkyard for like $20
http://www.s10forum.com/forum/f199/1...w-pics-145615/
ed3196499 08-19-2008 03:32 PM
I was looking at a buick at the junk yard the other day too had everything still there. Do you think this is strong enough for a full size hood? I cant wait to go back to the junk yard now.
dubdeuce80 08-19-2008 06:07 PM
yea, several people have used them, you just need to extend the middle with some pipe
old Rusty C10 08-19-2008 08:21 PM
lol im going for the stock look but that idea sounds cool ... LOL im wondering if i could/should do it to mine
S10Fan 08-19-2008 08:38 PM
I used the Buick hinge on my S-10, easy swap. Sure does make changing plugs a breeze, no more head hitting the hood. LOL.
Mr79C10 08-20-2008 05:54 AM
Interesting,,,
Would like to see this on a full size.
S10Fan 08-20-2008 06:01 AM
2 Attachment(s)
Found a couple pics..............
75sierraclassic 08-20-2008 09:14 AM
http://67-72chevytrucks.com/vboard/s...d.php?t=303294
There was a pick in this weeks "What did you get done"
N2TRUX 08-20-2008 09:35 AM
It's a cool mod, I just hate the way it covers the grill when open.
rod86 08-20-2008 10:11 AM
you could always fab up your own hinges so it tilts on front edge rather than tilting down over the grille, then put some gas struts to hold it up.
ca180 08-20-2008 02:24 PM
Thats was me in the what did you get done...
It really turned out to be a bigger PITA than I originally planned. But I'm not the best fabricator. I still haven't got the receivers figured out.
One thing I did find is that you want to brace under the stop bumpers. When the hood is open it puts too much strain on that spot.. Mine are bent down now, but I'll probably design a better system next go round.
Check this thread out from FSC, thats where I got the idea
http://www.fullsizechevy.com/forums/...g-my-hood.html
jrsmith_2010 08-21-2008 04:15 PM
im gonna try to do it, waitin till my local junkyard calls me back to see if they have any, i may need the help of those of you that have done it.
Restrorob 08-22-2008 09:46 PM
For the rear receivers/bump stops on my 74 C10 I had the same problem but figured out how to use the ones off the Buick as well.
I modified them as below then swapped the right side off the Buick to the left side on the truck visa-versa. Then I made the "L" bracket that holds the Buick striker/rollers ? that mount to the rear stock hinge bolt hole on the hood, You can see the flat washers under this "L" bracket used to adjust the rear of the hood level with the fenders.
The stock hood bump stops on the cowl will have to be removed to use the rear Buick slider track system.
http://i107.photobucket.com/albums/m...100_6008-2.jpg
http://i107.photobucket.com/albums/m...d/100_6283.jpg
http://i107.photobucket.com/albums/m...d/100_6281.jpg
http://i107.photobucket.com/albums/m...d/100_6280.jpg
http://i107.photobucket.com/albums/m...d/100_6279.jpg
I did all this just before I stripped the truck to the frame for the restore 5 years ago, That's the reason for the rust/unpainted pieces but will be detailed before re-assembly.
This set-up works just as perfectly as Buick intended it to on their cars....http://www.xtremesystems.org/forums/...s/thumbsup.gif
spoon 08-22-2008 10:05 PM
Definately a modification geared toward the enthusiast who wishes for easier accessibility to the middle/rear most portions of the engine. While doing so quite hideosly (sp?), the function-over-form aspect is apparent without question.
