flipping crossmember on new one
i was wondering the pros and cons on flipping the crossmember for the trailing arms or ordering one from ece with the exhaust holes. i can weld the rings in no problem, i was just wondering if it was worth the money and the effects on pinion angle on both. oh yea i do have a carrier bearing in the truck. thanks fellas.
Re: flipping crossmember on new one
Anyone have any experience here?
Isn't the ece and cpp crossmember for one piece driveshafts?
if i remember evil design flipped his, i was hoping he would chime in an give some helpful info, yes you are correct on the one piece drive shaft, but with a miller and a hypertherm anything is possible, just wanna make sure i am going in the right direction before i start hacking, thanks fellas.
