-   -   67-72 2wd lift (https://67-72chevytrucks.com/vboard/showthread.php?t=311609)
pcorriveau951 10-22-2008 03:41 PM
67-72 2wd lift
Does anyone know a way to lift the front end of our trucks or if there is a set of lift spindels available? Any information would be greatly appricated.
Thank You
stepn67 10-23-2008 11:17 AM
Re: 67-72 2wd lift
I don't remember where I got the following info, and I haven't tried it yet, but something you could research:
Lifted Spindles: 88-98 Chevy c1500.
Upper ball joints: 88-98 Chevy c1500
Upper A-Arm: 67-70 1/2 ton
Lower A-Arm: 67-68 3/4 ton
Lower Ball Joint: 88-98 Chevy c1500
Inner & Outer Tie Rods: 88-98 Chevy c1500
Center Link: 67-70 1/2 ton (needs to be reamed out to fit the new tie rods).
Brake Rotor: 88-98 Chevy c1500 6 lug
Calipers: 88-98 Chevy c1500
pcorriveau951 10-23-2008 03:08 PM
Re: 67-72 2wd lift
Thank you very much, i guess i have some parts to get and try it out, i will let everyone know what i find out
nightmare 10-23-2008 03:17 PM
Re: 67-72 2wd lift
how far are you wanting to go? i've heard that the 3/4 ton springs in a 1/2 ton setup will net ~ 2 inches of lift. i wanted to do this, but needed to get my truck on the road quick, and couldn't find any 2wd 3/4 ton springs. someone else may be able to clarify this.
stepn67 10-23-2008 03:51 PM
Re: 67-72 2wd lift
I used 3/4 ton V8 springs on the front of my 67 with 6banger, and got about 1 1/2 " over stock. Don't have any picts as it's torn down right now with no engine. Also, theres a guy running around town who got a spring shop to make him some new springs with about 3" of lift.
Arad68 10-23-2008 06:48 PM
Re: 67-72 2wd lift
I used 3/4 ton 2wd front springs on my 68 but did not like the ride. Very stiff. I went to Rancho springs and shocks. They said 1.5" on the kit but I got a whopping 3" total and the ride is a lot less stiff.
Here are the part numbers and links.
Springs - http://www.partsamerica.com/ProductD...ype=59&PTSet=A
Front Shocks - http://www.partsamerica.com/ProductD...ype=49&PTSet=A
Rear shocks - http://www.partsamerica.com/productd...ype=50&PTSet=A
The rear springs are stock 3/4 ton varible rate
http://www.partsamerica.com/ProductD...ype=60&PTSet=A
