cntr arm bush
is there anyplace that sells just the stock front a arm bushings.most of the auto part stores sell the shafts and the bushings as a kit.the reason being i've already pc the shafts and only need the bushings.thx.
Re: cntr arm bush
I was able to find them someplace, but it ended up being the same price or cheaper to buy the preassembled shaft with bushings installed from americanclassic.com.
I'll do some searching and see if I can find them again. |
Re: cntr arm bush
got upper and lowers all 4 for 160 from tim christian.
Re: cntr arm bush
I bought these from here http://www.energysuspensionparts.com...s.asp?cat=2330
Re: cntr arm bush
Re: cntr arm bush
Are you talking about just the little rubber seals that go on the shafts? If so then LMC has them for like $3.00 a piece. No place local had them, but I never checked with NAPA.
Re: cntr arm bush
no the whole thing
