lift
i have a 67' k10 and was wanting to put a suspension lift on it and was thinking about a 4'' lift but not sure so if anybody has an oppinion or pics i would be greatful thanks.
Re: lift
check out the different areas for posting. moving this to 4x4.
Re: lift
I think a 4" is great on any vehicle. What are you going to be mainly using the truck for light offroading, heavy offroading, street driving. I think its a great all around middle of the road lift. Sorry no pics check out the 4x4 pic section at the top of this forum.
Re: lift
I agree that a 4" lift is a great lift size. Modifications are kept to a minimum generally. BUT, your talking 1967 and that is different from the more simple to lift 69-72 years. There are a number of threads that address issues specific to the 1967 within about the last 4 months. If you can't find them, let me know and I will try to locate them for you. They will be a source of very good info for you.
Put a set of 33"s on your truck and you will have a nice appearance, but your tire won't be as heavy as a 35" so your mileage won't be as affected, and a little less wear on parts. These are bricks on wheels of course so realize a lift will affect your mileage if that is a concern. |
Re: lift
i lifted my 67 k10.i bought the 4 in kit for 69-72 and front springs fit fine. 4in block in rear and all i need was different u bolt and use stock spring plates.mines not done but 4 in suspension 3in body and 35s heres a pic.
Re: lift
did you get shocks with you lift
Re: lift
hey killa looks like you need to add the body lift to the bed too, it looks left out
cool truck though! |
Re: lift
killa looks great. like the tires you choose.
Re: lift
welcome, i'm building a 68 K-10 but opted for an add-a-leaf in the rear 1.5" lift and run 33 x 10.5
Might want to look into a new front axle to get power steering and disc brakes... all solid chevy axles will bolt up...this pic was stock with those tires... |
Re: lift
bed on just on to do body work lol ha need to chose a color its the hardest part.no shocks with kit bought from jcwhitney only cost 250.00.i really dont like the tires just got them cheap.looking for something eles
Re: lift
3 Attachment(s)
some pics with 31s that came on truck after lift lift pic |
