-   Suspension (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=25)
-   -   72' Chevy question (https://67-72chevytrucks.com/vboard/showthread.php?t=315405)
Mrwlliam 11-20-2008 09:54 AM
72' Chevy question
Ive seen a few pics in my search yieldings, but my question isnt awnsered yet...
Can i simply add a notch and bag on the stock rear links and sit low.. Im not totaly beat up on laying out yet.. Just want to lay low for now.. Any input?
And I think the front is just a simple bolt on setup.. from S/D maybe?
Thanks Guys,
Will
http://i274.photobucket.com/albums/j...ctures_002.jpg
http://i274.photobucket.com/albums/j...ctures_001.jpg
Mrwlliam 11-20-2008 01:00 PM
Re: 72' Chevy question
Bump For lack of input..haha..
mycool72 11-20-2008 02:07 PM
Yes, you can run the stock 2-link like I'm doing with a SD notch....adding blocks will give more drop if needed. Let me see if I can dig up a photo of mine on the two link without the notch....also keep in mind there are TONS of options on bagging, its all about preference and style..this site has a ton of info...so look around
mycool72 11-20-2008 02:09 PM
heres a quick shot of mine without the notch...adds a lot of drop..and def fun to play with
Mrwlliam 11-20-2008 02:58 PM
wow, great..Thanks .. Are those airlift bags?
Spray-Bomb 11-20-2008 04:19 PM
http://i81.photobucket.com/albums/j2...s/welcome2.gif to the board
You should check out the Texas CGITC in my sig ;)
IMO, you dont gain much from a bolt in notch & you will have to cut a hole in your bed floor for the pumpkin to poke through
If I were you, I'd run some Slammed Specialties RE-6's in the rear with no notch, unless you dont mind having a hole in your bed :rolleyes:
I dont like holes in my bed, so I didnt put in a notch when I bagged Sinister
And with Killer I did a frame Z & am raising the bed floor
Here is Sinister with no notch just bags
Ride height
http://i81.photobucket.com/albums/j2...8_02090002.jpg
Dumped
http://i81.photobucket.com/albums/j2...DSCF0005-1.jpg
Also, blocks will only allow the axle to sit higher when the bags are at optimal height, not dump any lower
Mrwlliam 11-20-2008 04:25 PM
Thanks Bomb...
You mean that if i put the blocks on iit will not allow the truck to sit lower?
The only time i have used blocks was on the rear of a s10..
Thanks for the pics, and great truck!
Ps. Can you tell me about the front?
Painter D 11-20-2008 07:37 PM
Here is a pic of how low you can get your truck without doing some form of major surgery. By major surgery I mean no Z'd frame, no step notch, no drop member, no hole cut out of the bed floor. This is a simple and easy setup using the factory trailing arms. Hope this helps.
mycool72 11-21-2008 10:31 AM
Yes, mine are airlift, I like them a lot but i'm prob gonna switch to the Slam Specialties cause they are huge and ride smooth as hell....
Shane 11-21-2008 10:58 AM
Great looking truck 69chevyshort! What size wheels and tires you running?
Painter D 11-21-2008 12:31 PM
20x10 w/275-40 out back. 18x8 w 255/45 up front
duceducenine 11-21-2008 07:09 PM
heres mine with c notch and standard front set up
Mrwlliam 11-21-2008 08:59 PM
Thats the standard notch? not the step(larger) notch.. That color is georgous...love the truck brotha.. and thanks for the info..
mycool72 11-21-2008 09:25 PM
If you're going to notch it, go with the step notch from SD...I think its only like 100.00, It would be a good investment, cause once you start going low, its only a matter of time before you want LOWER!!!
Mrwlliam 11-22-2008 10:57 AM
Way cool bro.. thats proly hat i will end up doing
