08 Jeep headlights in a square body
2 Attachment(s)
I was looking for a different headlight option for my 77. We had an 08 Jeep Wrangler at the shop for some work...then the tape measure came out, and it ended up with a trip to the Jeep dealer! Though not cheap ($ 108.00 ea.) with the bulb.They have a much more dome shape than the aftermarket clear style lights, and they bolt right in place of the originals! I have a couple pigtail plugs ordered for the bulb connection, but you could use spade connectors just as well.
Re: 08 Jeep headlights in a square body
Thats awesome. Wonder what newer model square lights would fit 81 and up?
Very nice,...
is it $208 brighter? they look good
Well judging by the jeep...i would say twice as bright as the truck originals! I had to order the other light (they only stock one!). Once i have the pigtails and the other light i will update.
nice tip there it might safe me a bit time getting european aproved lights for my truck (they sell jeeps close to my place in the netherlands)
That's cool!
That is too cool. I wondered if those were the same size. I'll bet they are much better than the aftermarket ones that are available.
could you do a side by side comparison once you get both of them...once you wire one up, you could compare each side by side and then wire the second up...
Chuck |
Good Find! What bulbs do they use? I like that enough to get a set if theyre much brighter.
i bet you can get them in xenon too
hey crawdad,
looks good!! so do you not have to modify the harness as all??? i know that on my '72 i would have to get relays to add brighter lights. i guess the voltage for the jeep lights requires the same as the factory light setup... they sure do look good, the extra shape adds a old quality to it.... i think anyways. thanks!! p.s. i am still really mad that i couldn't jump on that before you!!! (lol)..... stupid economy!, because of some stupid people now all the people have to suffer! |
look good crawdad..............i like em.
SWEET. I was looking at a Jeep last week wondering if they would work!
Did you get the jeep lights put in? You said it was a direct bolt in, right? I'm wanting to do this too, but waiting to see how it goes with your truck. Rockauto.com has the lights for $59.00 each. Then all I would need is pigtails and relays.
I did power the lights up a short while (i am relocating the battery and moding the harness some) They are at least twice as bright as the old sealed beams! Sounds like you found a killer deal on them! I used Mopar # 1-68018959AA pigtails without a relay. I have heard they are brighter with the relay set up. As far as bolting them in, the Jeep light comes with a mounting bracket and trim ring, throw that stuff away and bolt them right in with the GM factory retainer ring and your set ! ;)
Great! Post some more pic's when you get it all set up. Thanks
so if ya do the conversion you need a relay for it to work properly cause i have a 73 and that looks like a great change from the sealed beams. i hate the looks of euro lights that looks more OEM
cool hope you take pictures of the install
If you stay with the 55/60 watt bulbs you shouldn't need a relay. If you go with any higher wattages then you should deffinetly use a relay.
What model jeep did these come out of? NEVER MIND I RE-READ THE FIRST POST AND FOUND THE ANSWER... 08 JEEP WRANGLER. Frank |
