-   -   72 K-10 AC Removal (https://67-72chevytrucks.com/vboard/showthread.php?t=322051)
Heikes 01-03-2009 11:42 PM
72 K-10 AC Removal
Removing the AC system from my 72 K-10 because most of it is missing. I have the under hood portion figured out and have found a source to allow removal of the under hood housing. Here is the question, can I replace the underdash ac hard plactic ducting with a none ac hard plastic ducting? (I know the flexable air ducts are not a problem) The cabling, wiring and actuators are different but is that the only differance? Will mount in the same location?
JimKshortstep4x4 01-04-2009 08:36 AM
Re: 72 K-10 AC Removal
Welcome to the 67-72 Truck Board from West Michigan!
If you are wanting to replace the AC with the standard heater setup then it is a little bit of a project. The firewall holes for the AC and standard heating are different. It can be done but the question is : Will AC become desireable in the future?" AC in our trucks can be nice!
Jim
john 01-04-2009 02:30 PM
:welcome2: to the board. Heres the difference.
