-   Tools, Shops and Shop Safety (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=89)
-   -   Tools and their uses (https://67-72chevytrucks.com/vboard/showthread.php?t=322793)
bikerbomber 01-08-2009 11:13 AM
Might have been seen here before but I thought I'd share...
"tools and their uses"
> DRILL PRESS: A tall upright machine useful for suddenly snatching
> flat metal bar stock out of your hands so that it smacks you in the
> chest and flings your beer across the room, denting the freshly-
> painted project which you had carefully set in the corner where
> nothing could get to it.
> WIRE WHEEL: Cleans paint off bolts and then throws them somewhere
> under the workbench with the speed of light. Also removes
> fingerprints and hard-earned calluses from fingers in about the time
> it takes you to say, 'Oh sh -- '
> ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their
> holes until you die of old age.
> SKILL SAW: A portable cutting tool used to make studs too short.
> PLIERS: Used to round off bolt heads Sometimes used in the creation
> of blood-blisters.
> BELT SANDER: An electric sanding tool commonly used to convert minor
> touch-up jobs into major refinishing jobs.
> HACKSAW: One of a family of cutting tools built on the Ouija board
> principle. It transforms human energy into a crooked, unpredictable
> motion, and the more you attempt to influence its course, the more
> dismal your future becomes.
> VISE-GRIPS: Generally used after pliers to completely round off bolt
> heads. If nothing else is available, they can also be used to
> transfer intense welding heat to the palm of your hand.
> OXYACETYLENE TORCH: Used almost entirely for lighting various
> flammable objects in your shop on fire. Also handy for igniting the
> grease inside the wheel hub out of which you want to remove a
> bearing race.
> TABLE SAW: A large stationary power tool commonly used to launch
> wood projectiles for testing wall integrity.
> HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground
> after you have installed your new brake shoes, trapping the jack
> handle firmly under the bumper.
> BAND SAW: A large stationary power saw primarily used by most shops
> to cut good aluminum sheet into smaller pieces that more easily fit
> into the trash can after you cut on the inside of the line instead
> of the outside edge.
> TWO-TON ENGINE HOIST: A tool for testing the maximum tensile
> strength of everything you forgot to disconnect.
> PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under
> lids or for opening old-style paper-and-tin oil cans and splashing
> oil on your shirt; but can also be used, as the name implies, to
> strip out Phillips screw heads.
> STRAIGHT SCREWDRIVER: A tool for opening paint cans. Sometimes used
> to convert common slotted screws into non-removable screws and
> butchering your palms.
> PRY BAR: A tool used to crumple the metal surrounding that clip or
> bracket you needed to remove in order to replace a 50 cent part.
> HOSE CUTTER: A tool used to make hoses too short.
> HAMMER: Originally employed as a weapon of war, the hammer nowadays
> is used as a kind of divining rod to locate the most expensive parts
> adjacent the object we are trying to hit.
> UTILITY KNIFE: Used to open and slice through the contents of
> cardboard cartons delivered to your front door; works particularly
> well on contents such as seats, vinyl records, liquids in plastic
> bottles, collector magazines, refund checks, and rubber or plastic
> parts. Especially useful for slicing work clothes, but only while in
> use.
> DAMM-IT TOOL: Any handy tool that you grab and throw across the
> garage while yelling 'DAMM-IT' at the top of your lungs. It is
also,
> most often, the next tool that you will need.
I use the damn-it tool most often.....Have a good day guys.
-Bikerbomber
Longhorn Man 01-08-2009 11:55 AM
Re: Tools and their uses
That list never gets old!
The one that is missing on the vicegrips...
They can be used to stop the bleeding!
BigDaddyDave 01-08-2009 04:05 PM
Its good to know that all of my tools are working properly.
Billy81 01-08-2009 04:11 PM
I love the DAMM-IT TOOL..lol
