-   The 1969 - 1972 Blazers and Jimmys Message Board (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=36)
-   -   1972 Spray in bedliner Line-X Info + Pics (https://67-72chevytrucks.com/vboard/showthread.php?t=325454)
BlazerBoy 01-24-2009 10:19 PM
1971 Spray in bedliner Line-X Info + Pics
5 Attachment(s)
Ok here we go ..
I have a 1971 Blazer 4x4 I had all internal rust cut out and removed and replaced with the idea of having a spray in bed liner applied to not only hell with preservation but with sound as well. While I thought about it for a long time I finally went ahead with it and also to my amazement they were able to spray my top inside and out as well so I had that done as well. They offer many colors but I just simply chose black for the inside and the top changing my top from white to black. All I can say is i am extremely happy with my choice in doing this is looks like a brand new truck with a brand new top and the sound it a lot less noticeable now. The top has Xtra provides enhanced puncture and abrasion resistance, for a durable, custom, color-coded fit and finish. Fortified with DuPont Kevlar, Xtra provides unrivaled U/V stability and can be color-coded to manufacturer’s paint specifications! Or, if you prefer black, Xtra provides the same, long-lasting U/V stability for miles of maintenance-free protection for your truck. No matter how you use it, LINE-X Xtra with DuPont Kevlar, provides enhanced puncture and abrasion resistance, for a durable, custom, color-coded fit and finish.
Ok so I am going to post before hand pictures for now and will post the completed job with in a few days My camera is acting up right now so you can see what is started from at least haha.
BlazerBoy 01-24-2009 10:54 PM
Re: 1972 Spray in bedliner Line-X Info + Pics
5 Attachment(s)
Crappy pics i just took it gives you a idea i will have better ones in a few days and Also the guy took pics while they were spraying it and he is going to send them to me monday so i will post those also. but here is some for now
BlazerBoy 01-24-2009 10:57 PM
5 Attachment(s)
More
BlazerBoy 01-24-2009 11:00 PM
2 Attachment(s)
More :)
litebulblsc 01-24-2009 11:58 PM
If you don't mind the asking, how much did that cost?
By the way, it looks great and should last a loong time
BlazerBoy 01-25-2009 12:19 AM
800 for the bed and 300 for the top
OldCreek 01-25-2009 12:51 AM
Looks nice. How do you think spraying the top white would have worked out? Would it 'yellow' out?
BlazerBoy 01-25-2009 01:56 AM
Thats the only color they couldent do for some reason HAHA so i just went with black it works i am gona get the rest of the outside painted original tho.
BlazerBoy 01-25-2009 02:45 AM
Re: 1971 Spray in bedliner Line-X Info + Pics
Yeah i just realized i put 1972 I have a 1971 not that it makes a difference haha Dam that alcohol! LOL sorry if a AWESOME Administrator would like to change that 2 to a 1 that would be great! haha :) If not sorry :)
Otsa580 01-25-2009 04:28 PM
How well of a job does the liner do on deadening the road noise? The top and the bed look great! That looks like something I need to add to my to do list.:devil:
msgross 01-25-2009 04:34 PM
Do you think the outside black will add to the temp on the inside during the summer?
litebulblsc 01-25-2009 05:09 PM
Thats wierd that the top was cheaper then the bed?
BlazerBoy 01-25-2009 06:41 PM
The Road Noise is a lot quieter than it was for me its not like a Cadillac or anything it still sounds like a truck haha but if def killed about 40-50% of it so it was a pretty big improvement :)
BlazerBoy 01-25-2009 06:48 PM
I doubt it would be too bad but then again that has not been tested but The U/V protect ant coating on the top it supposed to help with that and fading. My tint helps also i have 100% U/V Block on my limo tint it cost a lil extra for the tint but i have had all of my cars tinted from the same place and that U/V block really helps on those summer days haha My M3 has black leather and without the tint on a 100 degree day it would be about 120 in there after 2 hours and now the temp only rises to about 85 so the tint will def help.
BlazerBoy 01-25-2009 07:03 PM
I guess but they had to do alot more detailed work on the bed Save the holes i needed and fill in the holes i dident need and remove panel plates and spray and then spray the plates and some other misc detailed work was involved in doing the bed all in all the whole deal i say was pretty in expensive for the multi purpose its going to serve. I am planing on keeping it so i am putting extra effort into it for preservation. Belive it or not that place can spray my entire truckmeaning the whole outside if i wanted to haha but i think that would be too much black and if i picked a color it would weird with like a textured paint haha it would prob last for ever then haha but i am just going to get the original paint on the outside :) but yes that place can spray anything really and it has a life time from any of there like 500 shops if somehow you do damage it and to prove that the guy sprayed a piece of metal they had around the shop while i was there and in about 5 hours after it dried i came back he gave me a hammer and tole me to try to damage or ship the material and i couldn't so its tuff stuff that's for sure.
drunkbus 01-25-2009 07:04 PM
Did they pull the windows out when they did the top or mask them off? I was going to do this to mine and was wondering how the window rubber would fit and seal if the top was sprayed with them out.
BlazerBoy 01-25-2009 07:56 PM
I had the option to do that but it would have cost more and the seal would have fit over it he showed me a example of that Or if i would have had No windows like if i pulled them out myself that would have worked too. but no on mine they just masked it and i am very happy with the way it worked out. I cant see any white anywhere so they did a great job, Also it did not ass that much weight to the top either i was impressed :)
drunkbus 01-26-2009 01:59 PM
I think I'll pull my windows and paint some black around the window area then put the windows back in with new seals before I have mine done. That way I won't have to worry about replacing the rubber sometime down the road and not having it match up to where they sprayed around the old rubber. I'm glad someone had this done and could give feedback. I had a thread about this about a year ago and never really got any info.
JWPOORE 01-26-2009 02:46 PM
I have been looking to do this for awhile as well. Were they able to spray the insides of your Blazer without taking the top off? I was just curious about that because I would like to avoid having to take the top off if at all possible. Looks great and thanks for the pics.
BlazerBoy 01-26-2009 05:16 PM
Um They helped me take it off and dident have a issue with helping take it off , It was highly recommended to remove the top.
Big J 01-27-2009 12:11 AM
Looks great. I'd like to see some shots of the outside in the day light when you get a chance.
BlazerBoy 01-27-2009 05:20 PM
4 Attachment(s)
Also here is my link to all of my pics Also you will notice a Blue blazer in there that does not belong to me i am using the pictures as a refrence to build a Rear tire carrier like that one.
http://gallery.me.com/shaunkore#100010
Big J 01-27-2009 09:36 PM
Cool. Thanks.
BLUE THUNDER 01-27-2009 10:22 PM
Nice ride. I've been thinking about doing the same to my blazer once I get rid of the rust. Cant wait to see more pics. Later, Mario.
BlazerBoy 01-29-2009 10:14 PM
More pics will be coming soon :)
