-   -   What is this thing? (https://67-72chevytrucks.com/vboard/showthread.php?t=325849)
softballnrd27 01-27-2009 03:12 PM
What is this thing?
I am cleaning up the friewall of all wires/and uneccessary stuff, what can I get rid of in this pic? I don't plan on using stock ac/heat but it has to stay until I get the aftermarket kit. What is the ball thingy in the middle of the pic? What else can I remove butstill retain the heat/defrost portion of it?
http://i154.photobucket.com/albums/s...k/IMG_0721.jpg
Pyrotechnic 01-27-2009 03:18 PM
Re: What is this thing?
It stores vacuum that operates the vacuum actuators for the ducts.
softballnrd27 01-27-2009 03:29 PM
So I need to keep it for the heat to work right?
vern350 01-27-2009 04:08 PM
Yes, or the heat will just go to the floor and not to the window. There should also be line going to the manifold.
thefatguy 01-30-2009 09:57 AM
On my 78, that canister is more squared off than that one, but it serves the same purpose. Currently all the hoses are plugged and tie-wrapped out of the way, because I don't know where they should go. Any pix of the end points of the two lines coming off that canister?
gmclowsierra 01-30-2009 03:13 PM
our trucks dont have vacuum actuators for the heat and defrost. its probably for emmission or cruise control. my bet woud be emmission.
silvereagle07 01-30-2009 03:28 PM
Pyro is correct, it stores vacuum for the vent, floor and defrost vacuum motors. The temp is adjusted by a manual cable (blend door).
silvereagle07 01-30-2009 03:32 PM
There is nothing you can remove in the pic and retain heat/defrost. You need the blower motor, resistor block, heater core and vacuum canister. What kind of aftermarket unit are you installing? I'm looking one for my dads' truck.
andrewmp6 01-30-2009 04:06 PM
Vintage air has a bolt in kit but you need heat only controls for it.
