-   -   Removing door hinges... is there a backing plate behind it? (https://67-72chevytrucks.com/vboard/showthread.php?t=331203)
CentralCoaster 02-28-2009 06:11 PM
I have the lower hinge almost off, but it feels like whatever the bolts on the cab side thread into is loose.
Is there a plate back here behind the A-pillar similar to the backer on the striker plate?
If I pull these bolts loose, is that going to fall into the door and get lost?
I haven't pulled the fender, I'm just using my gearwrenches to get to these bolts.
too much stuff 02-28-2009 06:15 PM
Re: Removing door hinges... is there a backing plate behind it?
It should be OK. It should be "caged" in there. It seems loose for adjustment purposes.
CentralCoaster 02-28-2009 06:17 PM
Thanks bigtime for the quick response!
Back to work...:metal:
CentralCoaster 02-28-2009 07:38 PM
Wow, I give up on punching the pin out of this. I'm going to buy new hinges.
