-   Suspension (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=25)
-   -   Air line (https://67-72chevytrucks.com/vboard/showthread.php?t=332169)
au03z71 03-06-2009 02:02 PM
Air line
I just ordered the Big Red 4-way valve pack from RideTech. What size airline should I run and what are the best fittings to use? I'm not looking to give myself whiplash when I air out the bags, just fine tune and not have a fitting blow out.
Let me know what the recommendation is, and also the best place to pick up this stuff...Thanks
hotrodhomi 03-06-2009 02:05 PM
Re: Air line
I used DOT rated 3/8". You can always slow it down if you wanted, but I think 1/4" would be way too slow.
au03z71 03-06-2009 02:50 PM
Re: Air line
Yeah that's what I was thinking. Where did you get your fittings from, and what kind did you use?
hotrodhomi 03-06-2009 06:48 PM
Re: Air line
I used Parker fittings from a local vendor. I used the DOT push connects.
