-   -   Gauge cluster (https://67-72chevytrucks.com/vboard/showthread.php?t=337121)
jbristo67 04-03-2009 10:07 PM
Gauge cluster
What is the blank guage to the right of the steering column
Longhorn Man 04-03-2009 10:11 PM
Re: Gauge cluster
on 10 - 30 series, nothing at all.
In the 40 series and up, if it had air brakes, it automaticly got an air pressure guage, and on hyd brakes/gas engine combos, there was an optional vac guage.
jbristo67 04-03-2009 10:17 PM
Re: Gauge cluster
Oh.......................... thanks is there a brake warning light
Sammy 04-03-2009 10:19 PM
Re: Gauge cluster
Yes in the dash
Longhorn Man 04-03-2009 10:37 PM
Re: Gauge cluster
lower left on the fuel guage. When you tirn the key to the start position, it is supposed to come on as a bulb test. If it doesn't light up, then check the bulb/socket/cluster/ect
