-   The 1969 - 1972 Blazers and Jimmys Message Board (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=36)
-   -   Original Blazer Owners: Grounding Strap Location and Number (https://67-72chevytrucks.com/vboard/showthread.php?t=337263)
tcb-1 04-04-2009 09:21 PM
My brother (bigdon-70blazer) and I have been trying to figure out the location and number of grounding straps for his K5 restoration. I have 3 on my 69 C-10. one on the left rear head to cab, one on the right rear head to cab, and one on the passenger inner front inner fender to the frame.
can someone check thier locations under the hood and if there are any more from the body to the frame, etc?
thanks gang!
jaros44sr 04-04-2009 10:09 PM
Re: Original Blazer Owners: Grounding Strap Location and Number
thanks gang!
Good question! waiting for responses also
bigdon-70blazer 04-05-2009 09:08 PM
I had Doug ask this question because I have 4 of these. I found the locations for 3, 2 on the firewall to the back side of the engine block (got a good pic of that) and one on the underside of the passenger side rocker box, got pic of that but did not get a pic of the last location, sometimes that happens! Please help.
jaros44sr 04-05-2009 10:04 PM
Can you show me the engine grounds, I don't think mine had them
70 Suburban 04-06-2009 07:26 AM
i had 2 one on the passenger side of the head on the rear to the body and one to the frame on the front of the exh manifold i think
bigdon-70blazer 04-10-2009 09:33 AM
3 Attachment(s)
Here are the pics of the ones I had. 1 on each side of the engine and 1 on the rocker box passenger side bottom. I can not remeber where the fourth one goes. Does it go on the radiator support somewhere? Please help and thanks!
jaros44sr 04-11-2009 09:03 PM
On the 2 firewall grounds, where does the engine side bolt to? Can't make it out in the pics
Johns70 04-11-2009 09:51 PM
ive always found them connected to the rear bottom valve cover bolts
jaros44sr 04-12-2009 08:42 AM
bigdon-70blazer 04-12-2009 01:56 PM
There is a hole there to the rear of the valve covers, threaded . that is where mine were.
jaros44sr 04-12-2009 03:56 PM
Really... I'll have to go look, is it in the head?
bigdon-70blazer 04-12-2009 08:48 PM
Yes. Let's put it this way, thats where I think it was so that is where I put them....I had the same problem, couldn't see there because I did not take a pic. Advice...take pics of everything!
jaros44sr 04-12-2009 09:27 PM
I was just down there looking, can you narrow down the search a little. Didn't see it on the head
Jtrux 04-12-2009 09:40 PM
If i'm not mistaken I have one (it's taken apart now) going from just above the heater box to the hood.
Nvm, it's my ford i'm thinking of...whoops.
jaros44sr 04-12-2009 09:44 PM
:lol: you're forgivin'
:lol:
